door ajar light
Old Jul 27, 2010 | 03:01 PM
AJMAG's Avatar
AJMAG
Default door ajar light
my door ajar light is constantly on, i have an 03 ram 1500 hemi, iv been messin with it for a while now and found out it was the wires in the back left door. is there a wire i can snip for an easy fix or do i gotta get a whole new wiring harness or latch?
thanks in advance
Old Jul 27, 2010 | 03:30 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The door ajar switch is located inside and a part of the actuator and latching assembly. It must be replaced as a whole unit. The only other thing you could have is a broken wire in the door or wire loom.
Old Jul 27, 2010 | 04:26 PM
lxman1's Avatar
lxman1
Site Moderator
Sometimes the switch gets sticky and you can spray the latch assembly good with wd-40 and it will fix it. Worth a shot before spending a bunch of cash.
Old Jul 28, 2010 | 07:38 PM
AJMAG's Avatar
AJMAG
thanks for the tips guys, after messing with the wires i found that i have a cut in one of them and it was grounding out or something. thanks again
