Brake Disc
Old Jul 29, 2010 | 02:26 AM
bdiddy80's Avatar
bdiddy80
Default Brake Disc
Does anybody have any ideas on how to remove the brake disc without using an air tool ? Also, what is the size of the 2 bolts that hold the brake disc in place?
Old Jul 29, 2010 | 06:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive never used air tools on my brakes although Im sure you can. Just use your standard ratchet and sockets. You may need a cheater bar or a hammer to hit the ratchet or wrench to break them loose depending on the last time they were done and who did them.
I think it is 13mm on the fronts and 10mm on the rears and 21mm if you want to remove the entire calipers. If you are asking this then i assume you do not have a complete 1/2" socket set. You really need to have some tools.... ;-)
Make sure you have something to compress the caliper pistons back in place with (several ways to do this) and grease the slider pins when putting it all back together. Ceramic pads are best and be sure to have the rotors turned or replaced while you have it all apart if you have ANY shaking in the steering wheel when driving and applying the brakes.
Old Jul 29, 2010 | 07:25 AM
loflyer2's Avatar
loflyer2
Check if disc is being held on by lock washers. When I remove the lock washers my discs come off easily by hand. I know some have needed to hit them with a hammer though. Are you changing discs? If not, you probably don't need to take them off.
Old Jul 29, 2010 | 09:04 PM
bdiddy80's Avatar
bdiddy80
Ok.Thanks
Old Jul 29, 2010 | 09:05 PM
bdiddy80's Avatar
bdiddy80
Thanks
Old Jul 29, 2010 | 09:08 PM
luckydt's Avatar
luckydt
also not sure about your neck of the woods, but here in NC you are able to rent tools from autozone, but it your break it you bought it.
Old Jul 29, 2010 | 11:22 PM
Marx's Avatar
Marx
my discs more or less fell off when i took the caliper off, original discs may have clips on the wheel studs that can be removed and tossed make sure you put anti-seizes on the disc where it touches the wheel, it will prevent the wheel from sticking to the disc, and grease the anti rattle clips. if you search the forums there are a couple threads with instructions
Old Jul 30, 2010 | 02:14 AM
abarmby's Avatar
abarmby
Here......this works a real treat and is soooo easy!
Sorry about the crappy music lol.
Al.
http://www.youtube.com/watch?v=mtsTJCRljAs
