3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Whaaaaaaaat? You telling me that if you have the 45, you have a 5 speed automatic that isn't using a gear?! Otherwise, how can a FLASH change from a 4 to a 5 speed? Someone PLEASE elaborate on this one...
I did find this thread, wanted to throw it out. I still don't understand how a TCM flash can add a gear, but I'm researching.
**wouldn't let me post the link**
its because this tranny is mostly electronic. a signal tells a solenoid where to send fluid and at what pressure, and depending on where/how it goes, it will engage a certain # of clutches giving you any given gear. there really arent mechanical "gears" inside the tranny. just a valve body, solenoid, and a bunch of clutch packs.
