E-Fan installed with pics
Old Aug 8, 2010 | 10:03 PM
ekgaudio's Avatar
ekgaudio
Be cautious in high heat though because in mine the solder inside the fan motor came loose from too much heat....Damn thing is a pain to pull all apart to solder one wire!
Old Aug 8, 2010 | 10:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Looks good and great job
Old Aug 9, 2010 | 02:33 PM
wolf22m's Avatar
wolf22m
I am about to do the same thing
Old Aug 9, 2010 | 07:07 PM
BadHab1t's Avatar
BadHab1t
see i thought it was ideal to use the 3.8l taurus fan be cause the low side pushes more air than say the 3.0l .... i was told only to use a 3.8l fan or else this would have been done a while ago those are always available....
Old Aug 9, 2010 | 08:50 PM
luckydt's Avatar
luckydt
jusjay727 not sure, but i know mine is the 3.0L and today was a hot one in stop and go traffic i never made it past the half mark on the temp gauge.
Old Aug 9, 2010 | 09:06 PM
blakeroberts88's Avatar
blakeroberts88
I want to hook your fan up on the high side to see how it would sound. If it sounds menacing it might compliment the truck You'd just need to get a bigger relay and inline fuse.
Old Aug 9, 2010 | 09:18 PM
luckydt's Avatar
luckydt
Well consider it a christmas gift. You buy it and will put it in, sounds good to me!
Old Aug 10, 2010 | 08:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats what I did with mine. I bought a 80/60A relay on ebay for $9 and a AGU fuse holder and a 5 pack of 60A AGU fuses for another couple bucks and started using the high side of the fan.
The relay contacts have to be filed down to fit my controller but it works.
Old Aug 12, 2010 | 12:29 AM
s13_marine's Avatar
s13_marine
I've towed my wife's Murano and trailer that weigh about 5K form Cali to AZ, up some pretty steep mountains, in upwards of 110 degrees, fan on low... never got above a little past 1/2 on the gauge.
Old Aug 12, 2010 | 09:57 PM
luckydt's Avatar
luckydt
update today was 98 degrees and still just below half in traffic on low speed.
