May do my first engine rebuild, Questions
Old Aug 9, 2010 | 03:04 AM
freestyledude's Avatar
freestyledude
Default May do my first engine rebuild, Questions
Now that I pulled the pan on the motor I just pulled and work with it a bit, it looks like one rod snapped and after removing that rod the motor turns over fine. With the difficulty I'm having finding a motor, what tools and information would I need to replace that rod? What do I need to have checked before I put this motor together?
Thanks
Old Aug 9, 2010 | 06:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The easiest thing to do (since you already have the pan off) is to break down the top of the engine (intake, accessories and heads) and go from the bottom of the engine and take a wooden handle and hammer and tap/push out the broken rod and piston out the top of the block and either buy a new piston/rings/rod or maybe just a rod and have the original piston pressed on. The only thing I can see you needing that you dont have is a piston ring compressor. Its a big band that goes around the piston and squeezes the rings. You then set it on the block and tap the piston down until the bottom of the piston skirt lines up with the bore and then give a good whack so the piston goes in the bore. Obviously you should oil the piston bore before pushing it in. But then once it is all the way down you can re-fasten it to the crank and torque the rod cap down.
Piston rings P/N - 05086002AA
Piston and rod for cyl 2/4/6/8 - 05086010AA
Piston and rod for cyl 1/3/5/7 - 05086011AA
Rod bearings - 05086003AA
Rod bolts - 06506335AA
Old Aug 9, 2010 | 12:47 PM
freestyledude
Quick question here maybe a silly one, but Would I be able to pull off the drivers side cylinder head with the rocker arms, valves, etc still attached?
Old Aug 9, 2010 | 01:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes and advised to do so as it is less work that disassembly and reassembly
