troubles after tune up
I am working on a 04 ram 5.7 l hemi..... recently done a tune up and now turck misfires on cold start up..... Only codes present are P0300 (random misfire) and a couple O2 sensors codes on bank 2..... everyhting looks good in my data stream..... I have been reading up on it a bit and some people think valve spring issue..... I am not convinced yet to pull a valve cover as everyone who has this valve spring issue has a rich code as well..... anyone have any other suggestions
I didnt think i needed to with just doing spark plugs and wires.... i have heard that some people believe there is a possible update however i do not have the resources to obtain that information without taking it tothe dealer (I was going to do that as a last resort).... is there a way to reset the PCM without taking it to the dealer (Ex. disconnect battery)
tryed resetting PCM by removing fuse for 10 minutes and didnt seem to help.... today I checked fuel pressure (Good 60 psi).... The snap on guy came in today and let us use his solus scanner to find misfire data.... got the misfire data up on the screen and it says that there are no misfires when you can definatly feel it missing so that was no help...... i removed all 8 plugs under coils and you can tell its running lean.... I put these plugs in a week ago and they look crusty white..... did a compression test to eliminate possible valve spring issue (all at 160)..... I plan to put it back together this afternoon (after cleaning the plugs up) and checking vacuum..... The boss already ordered a 02 sensor cause of the bank 2 sensor 1 code I am getting.... we are thinking possibly that sensor could be making her run lean.... dont know.... Its a last resort.... Not so sure its going to fix it but its another step forward
