Horn Location
Old Aug 11, 2010 | 09:19 PM
Matt99's Avatar
Matt99
Default Horn Location
Where is our horn? I have no idea, sounds like inner fender or something??
Old Aug 11, 2010 | 10:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It is behind the drivers side headlight. It is accessible from under the truck if you are good enough.
Old Aug 11, 2010 | 10:27 PM
Matt99's Avatar
Matt99
i just need to unplug it lol but there isnt a fuse for it on 06-08
Old Aug 11, 2010 | 10:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im sure there is a fuse for it but Im also sure it is not a dedicated fuse for JUST the horn. It likely may cover other circuits. But Im not totally sure being you have a later model and I dont have my DR Srvc Manuals in front of me. The best thing to do is pull the headlight or go from under the truck. As for the fuse, take the PDC cover off and look on the under side of the cover and see what fuse is for the horn.
Old Aug 11, 2010 | 11:03 PM
Matt99's Avatar
Matt99
yea Weed, i know there is a fuse linked to the horn but like you said, there are a few other vitals that use the same fuse.
I will do that i guess, whats it look like?
Old Aug 12, 2010 | 03:51 PM
Matt99's Avatar
Matt99
weed i dont think my horn is behind the drivers side light...i took it out and theres nothing that looks like a horn there
Old Aug 12, 2010 | 06:15 PM
Matt99's Avatar
Matt99
okay i found them...a high and low, both under the drivers side front quarter panel
Old Aug 12, 2010 | 06:33 PM
BadHab1t's Avatar
BadHab1t
why you unplugging it?....
Old Aug 12, 2010 | 06:46 PM
Matt99's Avatar
Matt99
whilst installing my BL i had my brother turning my wheel slightly to straiten up the slot where the pinch bolt goes. He overdid it lol. Broke the ribbon in my clockspring, so the horn was honking at full lock.
Until the clockspring comes in i am fixing the problem, because i cant have the honking with every right turn lol
