3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Are there any drawbacks to cranking the keys and going offroad? Besides rough ride and less articulation? What can be done to help soften those drawbacks?
I have mine cranked to the max but I think its because I did it back in 2008 when the truck was 5 years old with some sag. Mine sits perfectly level, about 1/4" lower in the front and I've been off roading and everything was fine. By off roading, I mean going through 3 ft desert whoops at 10 miles an hour which is gnarly, I don't recommend it. My ride is a little stiffer but It makes the truck feel more sturdy. I would think it gives you more articulation since your raising it but you definitely need longer shocks so you don't top out. IMO, crank them and see how you like it. If you don't like it, put them back. But ignore the clunk when the shocks top out. Just concentrate on the ride.
I suppose that is the number one question then..... Could I get level just by cranking the bar up?
I just did it on my newly acquired '05 4x4...I didnt jack it up, and I didnt need new shocks...it took all of 5 minutes, and Im level now. Probably raised the front about 1 3/4".
