35" tires, new spare?
Old Aug 15, 2010 | 12:50 PM
Marx's Avatar
Marx
Default 35" tires, new spare?
so when you guys upgraded to 35s' did you also upgrade your spare? is it necessary?
Old Aug 15, 2010 | 01:41 PM
Big_Wheel's Avatar
Big_Wheel
well only if you get a flat tire-- its good to keep a plug kit in your truck if you dont have a spare
bgbluram2's Avatar
bgbluram2
You will learn the answer to this question if you get a flat with your 35's. It may be tricky to fit a 35" spare under the bed, maybe someone with a larger than stock spare can chime in.
Old Aug 15, 2010 | 01:47 PM
HammerZ71's Avatar
HammerZ71
I have been running larger than stock tires on my trucks and 4x4 suv's since I was a teen and only once (Jeep Wrangler) did I buy a fifth tire. I always have both a tire repair kit and an off-road size can of Fix-a-Flat with me. Have had to plug a tire a few times, had to limp in once when I ran over a nail gun belt of framing nails (yeah was flapping away with a good dozen holes in the tire) for a big a$$ internal patch to be put on. Never needed to use the Fix-a-Flat though (I would only do so in an extreme emergency).
Been lucky for the most part.
You always here about how BAD it is to stick on a smaller (stock size) tire to get you to the tire shop in an emergency, but they been puttin' donut spares in vehicles for years, so I dunno?
Old Aug 15, 2010 | 03:45 PM
RubberFrog's Avatar
RubberFrog
Most cars don't have an lsd, that's why donut's are OK.
You can still use the stock spare, but you'll need to put the spare on the front and switch a tire around (depending on flat location).
Old Aug 16, 2010 | 12:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have 36s and an LSD but my stock spare was a 32". I dont keep my spare with me because of how my exhaust is ran. I do throw it in the bed when i go out of town but i also have my air tank and compressor as well as air hose. I also keep fix-a-flat and green slime with me as well just in case.
Old Aug 16, 2010 | 01:22 AM
Marx's Avatar
Marx
i don't mind keeping the spare in the bed i might just pick up a cheap 35" when i get my new tires
this has been a deciding factor between 33's and 35's just not sure what size to get, i don't off road much, a bit of field driving during haying season and few trips to the hunting camp so i don't need the articulation
thanks for the input!
Old Aug 16, 2010 | 10:43 AM
ekgaudio's Avatar
ekgaudio
Get 10ply 35's! They wont get flats easily
Old Aug 16, 2010 | 11:42 AM
tlawre87's Avatar
tlawre87
If you do throw it in the bed get a cable and a lock. Down here in oklahoma spare tires seem to disappear alot. That and tail gates.
