P127F Fuel Pump Circuit 2 Over Current
Old Aug 15, 2010 | 01:20 PM
A05GSHO's Avatar
A05GSHO
Default P127F Fuel Pump Circuit 2 Over Current
My truck threw the above code how do I fix it? Thanks
Old Aug 15, 2010 | 02:49 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like the pump may be failing. Does it run ok? have you reset the code and did it come back?
Old Aug 15, 2010 | 04:47 PM
A05GSHO's Avatar
A05GSHO
It wouldn't start so I got my Superchip Flashpaq and plugged it in and it gave me that code. Maybe 5-10 minutes later I tried it again and it started. Drove it home from the north woods, about 150 miles, 2.5 hours, shut her down and 5 minutes or so tried to start it and it fired right up.
EDIT: Trucks been sitting for 30-45 minutes now while I updated my 3815. Went out and plugged it in after the updates and I cleared the code. When it was done the truck started right up. We'll see what happens in the morning.
Old Aug 18, 2010 | 05:42 PM
A05GSHO's Avatar
A05GSHO
Well after $54.91 the dealer says
"Diag inspect wire resistence and wire connections all good. Stored code can be because of a long crank time. Overfilling fuel can cause this"
