5.7 Hemi MDS Issue?
Old Aug 18, 2010 | 12:05 PM
Mopardude18's Avatar
Mopardude18
Default 5.7 Hemi MDS Issue?
I have a 2007 Ram 1500 Quad with a 5.7 Hemi. It recently started to cut out at around 35-40 MPH when the RPM's are hovering around 1500-1700. I have been running 91 gas and have ran two bottles of injector cleaner thru the crazy thing. Is this the MDS or should I look elsewhere?
The truck has good power and seems to work fine otherwise.
Thanks!!!!!!!!
Old Aug 18, 2010 | 12:13 PM
2006NightRunner's Avatar
2006NightRunner
Is there Check Engine light ON? Are there any Codes?
Old Aug 18, 2010 | 12:30 PM
Mopardude18
It shows no other issues. No lights at all. I have not hooked it up to a computer for any error codes.
Old Aug 18, 2010 | 01:43 PM
Marx's Avatar
Marx
my 05 without MDS really bogs down around that speed its a common problem a tuner will fix it
what do you mean by cut out?
Old Aug 18, 2010 | 03:49 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like the MDS kicking in. Usually the tach will rise a couple hundred rpm when it kicks in. Put it in tow/haul mode and see if it goes away, if so, it's just the mds doing it's thing.
Old Aug 18, 2010 | 07:04 PM
Hyazakite's Avatar
Hyazakite
I agree, I work for a roofing company and we spend a lot of time in neighborhoods where the speed limit is 5-30 mph. The truck goes back and forth from MDS on to MDS off the whole time. I just put it in tow/haul mode when I have to drive at lower speeds.
Old Aug 20, 2010 | 09:03 PM
Mopardude18
I will try it out tomorrow. Is there a way to shut of the MDS?
