Please help on throttle issue.
Old Aug 24, 2010 | 11:26 PM
millzy's Avatar
millzy
Default Please help on throttle issue.
So a few weeks ago, I took off my throttle body to clean it and then started getting the red lightening bolt of death when excelerating. After searching and reading the forum I figured that I probably screwed up the throttle body by manually moving the butterfly. Yesterday I received my new throttle body from Fastman and installed it tonight. During the install I unhooked the positive battery terminal. Before starting the truck, I followed the instructions for the PCM clear.
Now after driving the truck I am really confused. I can definately dirve more aggressively, but if I go over approx. 3500 rpm, I get the red lightening bolt again. Did the key trick and am throwing codes 2101 and 2110.
P2101 Throttle Actuator Ctrl Motor Circ Range/Perf
P2110 Throttle Actuator Ctrl Sys-Forced Limited RPM
Any clues on what to do next? I am at a loss.
Old Aug 25, 2010 | 07:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Try looking here.
B/C/P/U 2004-2006 codes in full details from AllData
Old Aug 25, 2010 | 09:36 AM
truckin151's Avatar
truckin151
Do you have a way to clear the codes? Just doing the PCM reset wont clear them (or at least going that rout has never worked for me). If you have a tuner you can clear them out or go down to a local autozone/checker/oreily/napa and see if they can clear the codes out. There may be a possibility that those codes are residual codes from your old TB not the fast man TB. So you need to make sure the codes have been 100% cleared before doing anything else.
