The 180 T Stat Mod
Old Aug 25, 2010 | 01:37 PM
pjordan4477's Avatar
pjordan4477
Default The 180 T Stat Mod
Why would I install a 180 T Stat?
Old Aug 25, 2010 | 01:59 PM
Marx's Avatar
Marx
keeps the engine cooler
Old Aug 25, 2010 | 02:08 PM
badblackram06's Avatar
badblackram06
A 180 degree thermostat will keep the engine cooler therefor will perform better and last longer. The only reason newer vehicles have higher temp thermostats is because its supposed to help with emissions.
Old Aug 25, 2010 | 02:53 PM
HammerZ71's Avatar
HammerZ71
Higher temp t-stats = leaner A/F ratio, better gas mileage, less emissions & less oil sludge.
Lower temp t-stats = richer A/F ratio, more power & longer engine life (although this is in theory, never really proven)...
Old Aug 25, 2010 | 04:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And dont forget these two threads about stats in our FAQs
Thermostat part #s
What temp thermostat you runnin!
Old Sep 11, 2010 | 05:56 PM
pjordan4477
I'd like to come back and add that the t-stat from the factory is set at a temp for premium performance (mileage/power). Lowering the temp would keep engine cooler, but the air to fuel mixture is based on the Air Temp not the block temp. The warmth of the block warms the lubricants and parts for the most efficient movement.
WITH THAT SAID...I will put in a 180 when I start traveling with the camper (28' Fifth Wheel) 3 and 4 times a summer. The extra work could use the water flow opened sooner then later.
Old Sep 11, 2010 | 08:38 PM
yellowbeast's Avatar
yellowbeast
how exactly does it keep the engine cooler i have the fan clutch and i thought that the hotter the engine got the more the metal in the fan expanded making it spin faster
Old Sep 11, 2010 | 09:06 PM
Hahns5.2's Avatar
Hahns5.2
Actually studies find that lower temps increase cylinder wear. The difference between 195 and 180 is small but once you go below 180 wear increases quite a bit.
Old Sep 12, 2010 | 09:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
On a side note, i've seen guys run 170's with no issues. But as we all know, their hemi is not your hemi. Just because theycan get away with it doesn't mean i or we can. But that's not to say we cannot either.
Old Sep 12, 2010 | 08:41 PM
horatio102's Avatar
horatio102
The coolant inside your engine does not go through the radiator until the thermostat opens up. A fast spinning fan won't do anything but cool the fluid inside the radiator faster until the engine itself hits X temp.
With a 195 degree thermostat, once the coolant in the engine hits 195 degrees then the thermostat opens and allows the coolant to flow into the radiator, and the cooler fluid in the radiator circulates into the engine.
Running a 180 degree thermostat makes that happen at 180 degrees instead of 195.
