Do I need to remove the leveling Kit ????
Old Aug 30, 2010 | 01:05 AM
Marx's Avatar
Marx
could be a front u joint
Old Aug 30, 2010 | 06:17 PM
LinerJoe's Avatar
LinerJoe
My '07 shudders when in 4hi at around 30mph, otherwise fine. It did it after installing the 2.5" leveling kit. I rarely use 4wd, so I'm keeping the level. When I do use the 4wd, I'm usually going faster or slower than 30mph, so I don't notice it.
joe
Old Aug 30, 2010 | 07:22 PM
brettj2408's Avatar
brettj2408
your shake is probably your cv axles at a higher angle. not a transfer case.
Old Aug 30, 2010 | 08:41 PM
velocity37's Avatar
velocity37
yah thats what i figured as well, whats the fix ? is there a fix? how much of a problem is it, I use 4x4 for a total of about 17 minutes a year
Old Aug 30, 2010 | 08:54 PM
brettj2408's Avatar
brettj2408
i live in minnesota and even during the summer months i put my truck into 4x4 at least 2 times a month to ensure when the winter months come im not scrambling to fix something that went wrong right when the snow hits. that way i have time to fix it.
i would try the alignment first and if that doesnt cure it your 2" is too high and maybe go down a step (if they make 1" or 1.5" level kits) no idea
Old Aug 31, 2010 | 12:02 AM
jorgysram's Avatar
jorgysram
other option is to talk to kore, they make a high angle cv joint for the inside of our half shafts, i think you can get them for around 600, its part of a kit but i know they sell just the joints also
http://www.koreraceshop.com/dodge-ra...ies-06-08.aspx
