Do I need to remove the leveling Kit ????
Old Aug 26, 2010 | 08:40 PM
velocity37's Avatar
velocity37
Default Do I need to remove the leveling Kit ????
Installed a 2" leveling kit today on my 06 1500. On the road test I popped it into 4x4 and it shook during acceleration. I never had the truck in 4x4 until this test so I am unaware if the shake was there before or if it is due to the leveling kit.
Should I uninstall the kit ??
How bad is the shake for the components ??
Old Aug 26, 2010 | 09:02 PM
glass3222's Avatar
glass3222
Did you get an alignment after the level install?
Old Aug 26, 2010 | 09:08 PM
velocity37's Avatar
velocity37
not yet
Old Aug 26, 2010 | 09:15 PM
glass3222's Avatar
glass3222
Get an alignment. During the alignment, have the mechanic check over everything. If it is still doing it afterward, then you have an issue.
Old Aug 26, 2010 | 09:39 PM
HammerZ71's Avatar
HammerZ71
Yep don't jump to conclusions until after the alignment, even a modest level kit throws the front end geometry out of whack...
Old Aug 26, 2010 | 09:47 PM
velocity37's Avatar
velocity37
I can see that the camber is way out , at highway speeds it is smooth no wobbles. Just when in 4x4 I know it os a known issue and I will reassess after the alignment. If the shake is there after all is aligned whats the solution ??
Old Aug 26, 2010 | 09:54 PM
HammerZ71's Avatar
HammerZ71
Pull the spacers. I dunno what the hell the difference is but some people with the '06+ coil over front 4x4s report terrible vibration issues after only a level while others don't get it at all. Hopefully the alignment will correct this...
Old Aug 27, 2010 | 01:36 AM
ram_bo06's Avatar
ram_bo06
06' myself w/ a 2.5" level. No shake in 4x4 or not. Alignment is key!!! after a level. Hopefully that'l do the trick for ya.
Old Aug 27, 2010 | 12:28 PM
jorgysram's Avatar
jorgysram
ive got an 06 with the 2.5 level also, knocked my alignment out one day off road with a hard hit on driver side of the truck and started to get that rele bad vibration, had the alignment done and it went away
Old Aug 30, 2010 | 01:01 AM
velocity37's Avatar
velocity37
I went and got a 4 wheel alignment done as well as had all 4 ball joints replaced (spicer greaseables). There is still a slight shake when in 4hi. I do not wanna remove the level because it looks good, what do you guys think about bringing the truck to a 4 wheel shop and see if they can adjust the transfer case at all ?
