cel question
Old Sep 3, 2010 | 02:12 PM
mbaseball3's Avatar
mbaseball3
Default cel question
on a trip at the moment and just had a cel light come on. pulled over right now to check it by using the key turn trick but no code is showing up. just dashes for a min then the word done shows. any idea what's the deal with this? thanks. googled the problem and others of different vehicles have had similar issues so obviously its an effin computer problem....
Old Sep 3, 2010 | 02:38 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why not go by some place like Autozone and let them connect a OBD scanner to the truck and see if they can get anything.
Old Sep 3, 2010 | 03:03 PM
mbaseball3's Avatar
mbaseball3
lol we're literally in middle of nowhere. north east part of fresno ca on our way to tin buck to turlock lol. hoping they'll have some auto store there. just mainly curious if anyone knows what's the deal with a ghost cel light
Old Sep 3, 2010 | 03:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive read where CA doesnt allow code scanning anyway. But you can get a light and it not be recorded being the trouble havent been triggered enough to be logged
Old Sep 3, 2010 | 03:30 PM
mbaseball3's Avatar
mbaseball3
weird? so I shouldn't worry? yeah ca as far as I know still let's us check obd at autozone. I have a code reader just haven't dug it out yet after our move.
Old Sep 3, 2010 | 03:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If it is coming up now it will come back later. Its just a matter or time and circumstance.
Old Sep 4, 2010 | 01:47 AM
mbaseball3's Avatar
mbaseball3
ok might this be the case....in continuation of todays snafoo, I couldn't unlock my truck with the key fob. obviously battery died right? I'm at a hotel and am still not set up like I should be (no tools). fortunately dude at front counter had screw driver that fit screw. upon opening the fob something struck the hmm button. the solder that holds the battery to the chip is completely unhooked. knowing that there is a security chip inside the fob could that be the reason of the ghost cel? and if the battery connection isn't connected could that mean the truck with not travel the distance because the chip no longer connects and shut me down? also truck is used when I got it and only came with one key. dodge wanted to charge me 100 for 2nd key. I purchased lifetime powertrain warranty when I got truck, does it cover new fob replacement? regardless I'm throwing a chit storm when I get home and getting it replaced. cause this ain't cool. thanks for any insight
Old Sep 4, 2010 | 06:33 PM
lxman1's Avatar
lxman1
Site Moderator
Not part of the powertrain. You might be able to get it a little cheaper from a local locksmith. It takes 2 good keys to be able to program a 3rd yourself. If only one key, the dealer must do it
Old Sep 5, 2010 | 09:17 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I think you can buy those keys on ebay but getting them programmed requires the dealer
Old Sep 6, 2010 | 09:50 PM
mbaseball3's Avatar
mbaseball3
thanks for the help. got it repaired at the dealership. still getting this ghost code. but goes away after awhile. and I only got it after about 100 miles on the freeway. city streets, I have yet to get it.
