Help me understand limited slip
Old Sep 11, 2010 | 12:52 AM
That1guy's Avatar
That1guy
My 02 is at 94k and the LS is doing okay. I assume it's fine. I havent lost an axle shaft yet.
Old Sep 11, 2010 | 01:06 PM
Mega-Hemi's Avatar
Mega-Hemi
The "C" clip that holds the axle in is not the clip they are talking about. These are little retaining clips used when installing the clutch packs. If you've got more than 50k miles on your LSD I guarantee you've got at least one broken clip in there(there's 4 total). Pull your cover off and take a look before it's too late. the LSD will still continue to work with a broken clip, you just run the risk of getting a piece of the clip jammed between the gears and grenading your rear end.
Old Sep 14, 2010 | 08:24 AM
tenntech's Avatar
tenntech
Yeah, I'm pretty sure I know which one we're talking about. I've rebuild a few of these diffs over the past several years working in a dodge dealership. I also know that my '02 ram with 150k miles has never had a broken limited slip clip broken. I may find it broken next service, but as of last service it's still good! I know it's a common problem and I know that people that has performed regular maintenance on their diff's have still had problems, but maintentance does HELP prevent this problem due to reducing clutch chatter!
Old Sep 14, 2010 | 05:27 PM
Mega-Hemi's Avatar
Mega-Hemi
That post wasn't directed towards you but OK, yours may be the exception. Congrats.
Old Sep 15, 2010 | 10:39 AM
lancer821's Avatar
lancer821
My diff is chattering when making a turn pulling my boat. It has been serviced every 30k miles and now has 70k on it. It is a rebuildable unit or is there something else out there better to replace with?
Old Sep 15, 2010 | 10:42 AM
That1guy's Avatar
That1guy
Yeah a Detroit true trac is great, but it cost 500 bucks and you gotta pay someone 300 dollars to setup the rear end. It never wears out since it's gear driven instead of clutch driven. It works a lot better too.
Old Sep 15, 2010 | 12:51 PM
HammerZ71's Avatar
HammerZ71
Anything is better than the stock LSD even without the clip issue. Not a very efficient unit. Very low bias and it often has to be "assisted" by using a little brake or the e-brake just to engage!
As far as the clutches wearing, I had an Auburn in my 2nd Gen and at 68k when I traded the truck in, it still worked like it did on day one. Auburn rates the units for 100,000 miles with HEAVY use.
I have an Auburn in my 3rd Gen as well. Wanted to try a TruTrac but at the time, Detroit was in the process of being bought out by Eaton, and NOBODY had the DTT for the 9.25" AAM axle and couldn't get a firm ship date. Another factor was (at least at the time), the manufacturer did/does not recommend the DTT for tires over 33" (although I've since known MANY guys with bigger tires and a DTT and NO ISSUES).
Rule of thumb is DTT for off-road use, Auburn for a street/strip truck. The clutch system engages slightly faster than the gear system for slightly better times. ALSO the Auburn is available in a PRO series with a considerably higher bias than their Performance series or a DTT. Not very streetable, but lock up is close to a true locker...
Old Sep 15, 2010 | 01:26 PM
lancer821's Avatar
lancer821
Thanks for the help. I guess I'll be putting in a new LSD soon. I might as well look at gears while I'm at it. Truck has 3.92 gears and the 20in wheels with 265 70 20 tires. Pulling at 65mph the truck is at 1850 rpm and with tow/haul at 2100 rpm. I tow my 24ft boat for about 75% of my driving. Any suggestions on gears?
Old Sep 15, 2010 | 01:31 PM
HammerZ71's Avatar
HammerZ71
The ones to stay away from are US Gear. About anything else is as good as the guy you pick to do the install. With gears, it's ALL about the installation...
