Help me understand limited slip
Old Sep 4, 2010 | 11:04 PM
PRF66's Avatar
PRF66
Default Help me understand limited slip
I have a $325 option Anti-Spin Differential Rear Axle on my 2007 Ram Quad
Cab. Is this the Notorious C clip dropper LDS? Thnk you
Old Sep 4, 2010 | 11:32 PM
HammerZ71's Avatar
HammerZ71
Yes, yes it is, although it's supposed to have sturdier clips than previous models, there are still '07+ guys who have had the issue.
and for a better understanding of limited slip:
https://dodgeforum.com/forum/3rd-gen...p-defined.html
Old Sep 6, 2010 | 10:18 AM
PRF66's Avatar
PRF66
Thank you for your reply. I just hope when I punch it I don't hear snap, crackle and pop noises. Have you ever snapped floored a truck and snapped an axle? It is a nasty loud noise not to mention a bit embarrasing. If I can avoid this from happening I'd like to, then of course I could hope for "gee what is that noise" as it grinds to a halt. Again, Thanks for the reply.
Old Sep 6, 2010 | 12:11 PM
HemiRam1566's Avatar
HemiRam1566
i havent had and issue with my LSD in my 07.. would it be a good idea to have it replaced with a auburn or eaton set up? i dont want to have it brake and take my gears out.. thats more money.
Old Sep 6, 2010 | 12:34 PM
HammerZ71's Avatar
HammerZ71
Even though the clips are supposedly stouter, I have never been impressed by a Chrysler LSD, most often to get it to even engage you have to apply a slight amount of brake or e-brake and even then the bias is relatively low, so you'll still get a lot of "one wheel peels".
If it's in the budget, get you an Auburn or DTT...
Old Sep 6, 2010 | 07:15 PM
tenntech's Avatar
tenntech
Just service the diffs regularly using mopar synthetic fluid and mopar limited slip additive. The earlier models recommended every 15,000 miles, but they changed that around 07' I think. Check your manual. My 02 has 150,000 with no problems. Regular maintenance goes a long way!
Old Sep 6, 2010 | 09:25 PM
HammerZ71's Avatar
HammerZ71
If you are the original owner and have 150,000 miles on the original stock LSD WITHOUT breaking a clip, congratulations, because I believe you'd be about the only one!
Regular maintenance is imperative with everything, including the differentials but the clips are a design flaw and changing fluids with or without additive has NOTHING to do with the clips breaking.
Old Sep 7, 2010 | 08:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know mine were founds broken around 60k but there is not telling how long they have been broken already and sitting in there.
Old Sep 10, 2010 | 10:40 PM
tenntech's Avatar
tenntech
Changing the fluid w/o using additive definitely will cause this problem worse. With no additive it causes the clutches to chatter when turning and gives additional wear.
Old Sep 10, 2010 | 11:46 PM
The Bull's Avatar
The Bull
I just turned 170k on my 02 and the rear end is still spinning strong and i have never changed the fluid..... i have thought about it recently though . Knock on wood "knock knock"
