Big problem
lol i don't have pics of what is broken...if i can get sum i will... had the flat bed come pick it up b4 i took the diff cover off to look. o well ill find out in a few days wat is going to be needed.
well, the shop looked at my truck today an told me it was the pinion an the gears... after i paid 60$ to have them tow it to there shop knowing that sum thing in the front end was broke they picked it up AND took my 60$ now they want to tell me they dont have to TOOLS! to fix it.. nw i have to spend another 60$ have it towed back to my house! so 120$ for them to tell me sorry we don't have the tools? wtf kind of crap is that!
Some Rams require a specialty tool to remove the gears from the truck. You may have to take it to a Dodge Dealership if you want to replace just the gears. It depends on which set of axles you have in your ram. I've been lucky so far with my ram and not having any problems, I have an American Axles 4.10 gear ratio. However I've had every common problem that a ram owner can encounter. Hope you can get it repaired soon
today i had time to jack the truck up an look in the pumpkin an see what is going on.. the barring went out in the pinion and the pinion was eating the case away. so now i need a new case an a pinion and my gear is not broke but in SOME spots it is bent so i think im just going to buy a whole new pumpkin for the front in with 4:56 gears
Would the auburn hear limited slip differential for 84-present chry 9.25, be a good buy for the front end?
Auburn Gear Limited Slip Differential for 84 - Present Chry 9.25
