Changing spark plugs
Old Sep 15, 2010 | 04:05 AM
  #21
Ramvortex's Avatar
Ramvortex
So you you should not use platnim????
Old Sep 15, 2010 | 06:22 AM
  #22
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would put in what you pull out. Why use Platinums when the truck didnt come with it and runs just fine as it is? I changed mine at about 60k or so and all the plugs on the HEMI are the same. As said before, there is no top or bottom. If you went out and looked at your HEMI engine you wold see that and how they are setup.
However, that "top and bottom" design sounds more like how the 4.7 guys do thiers.
So do you have a HEMI (5.7) or the 4.7 engine?
Old Sep 15, 2010 | 01:34 PM
  #23
Ramvortex's Avatar
Ramvortex
I never ask about the top and bottom, just wondering about what plug you guys suggested. I have a 5.7 Hemi
Old Sep 15, 2010 | 06:45 PM
  #24
MikeHTally's Avatar
MikeHTally
Originally Posted by Senomar_DTK
I think you will have to do 16 plugs and what the guys above said is good and you should also apply some dielectric grease to the threads of the new plugs before you put them in. Oh and if you can blow out any debris that may be in each spark plug hole.
Dielectric grease does not go on the threads, it goes on the top connector. Anti-seize goes on the threads.
Old Sep 16, 2010 | 07:35 AM
  #25
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^^ Thats true.... LOL
Old Sep 16, 2010 | 06:33 PM
  #26
MikeHTally's Avatar
MikeHTally
Originally Posted by weedahoe
I would put in what you pull out...
Sounds like good advice.
Old Sep 18, 2010 | 09:19 AM
  #27
jamie700r's Avatar
jamie700r
I just did my plugs last weekend after reading many threads about them. I used Anti seize on all the threads and dielectric grease on all the plug boots. All of them went fairly smooth with the exception of the 4 near the master cylinder. I used a 5/8 socket with a swivel attached and a 2" extension. I layed a blanket across the engine and layed across the engine. Only took about 20 minutes to remove them and reinstall them. It also helps to remove the intake before you do this.
Old Sep 18, 2010 | 01:02 PM
  #28
rideon20z's Avatar
rideon20z
Just did mine last night , took off the driver side tire and inner fender well and got to the back 4 plugs easier that way , the passenger side took off intake and did all from the top , wasnt a bad project in total about 3 hours i used copper champion plugs .
Old Oct 3, 2010 | 09:33 PM
  #29
JonP's Avatar
JonP
I bought the Champion copper plugs and some Bosch wires from the Zone and took the truck to a mechanic to install them for me as I've never done it before. When I got the truck back the check engine light came on. So I took it back and he checked the code and said it was a coil pack misfiring.
So he ordered another coil pack, installed it and sent me on my way, no charge!
The total cost was $86 which includes inspection.
Old Dec 16, 2014 | 05:10 PM
  #30
jacks187's Avatar
jacks187
Default top and bottom???
MainRam2500, you said 30,000 mile plugs on the (TOP) and 90,000 on the (BOTTOM)???? I didnt know there was a difference in the milage on plugs? Which is the top side and which is the bottom??
