Weird heater issues
Old Sep 9, 2010 | 02:51 PM
ELVIS56's Avatar
ELVIS56
Question Weird heater issues
Hey everyone,
I have searched and searched several sites looking for a similar problem but most are only vaguely similar. Here is the issue. I have a 2006 w/5.7 engine, 68,000kms that on random occasions with the heater on only blows warm air out of certain vents. I read that if you get cold air on 1 side and warm air on the other it could be a clogged heater core. Well, for 2 days I couldnt get warm air out of the defrost(windshield)setting but warm air would blow through mid vents and on floor. I only checked this today after some research but with the truck warmed up I was getting only cool air on windshield vents(both sides), heat on mid vent only on drivers side, and heat on floor only on drivers side. Then I left the truck idle for 15 minutes while I was at the store and BEHOLD when i got back in there was heat blasting from everywhere. I know it is not a warm-up issue as I have driven the truck on the highway to work(30min at 110kph)with this problem, but the problem seems so random.I may not have this issue again for a week then poof there it is again. I did check my upper water hose and it wasnt very hot. havent checked the bottom yet. Im leaning towards the t-stat, clogged core or air in the system. Looking for advise on other possible causes and educated opinions. Thanks.
Old Sep 9, 2010 | 05:23 PM
dodgeboy1979's Avatar
dodgeboy1979
sounds like your blend doors may not be opening in your dash allowing the warm air out certain vents. I believe this is vaccum controlled in this year of truck. The gen 2's had the same problems if you go to the gen 2 site and search wild vents it may help you. Your heater core sounds fine as you are getting heat just not to the right vents.
Old Sep 9, 2010 | 05:25 PM
dodgeboy1979
https://dodgeforum.com/forum/2nd-gen...ild-vents.html
here's the link. Where in alberta are you from?
Old Sep 18, 2010 | 10:06 AM
ELVIS56's Avatar
ELVIS56
Thanks Dodgeboy, I am going to check out the vacumm lines first then go from there. Actually havent had the problem again until yesterday. I was fooling with the dash controls and I turned the fan completely off and listened to the doors moving and with the fan off something worked because then heat was flowing again. BTW I live in Central AB just north of Red Deer.
Old Sep 18, 2010 | 04:21 PM
MikeHTally's Avatar
MikeHTally
Kinda funny to have heater discussions. It's 93 here today. Sounds like the blend door issue. The heater core has nothing to do with air direction.
Old Sep 19, 2010 | 08:10 AM
ELVIS56's Avatar
ELVIS56
HAHAHA, I hear your pain, it must be rough with the sun blasting and the sweating and all in Florida. Not to mention the hot and sweaty girls on the many beaches. Believe me when I say that I would rather be there cause we had frost on the ground yesterday and the weather says chance of snow for next week. I really am partial to the coast though as I lived on the east coast all my life up until a short while ago. Just farther north. As for the blend doors, I left the adjuster on defrost while the heat was coming out and then 2 days later now the heater is blowing cool on the defroster setting without changing it on the dash. So the doors must be moving on their own. I am going to check on some of the vacumn lines today and hopefully that solves it. As long as I dont have to rip the whole dash out to fix this I'll be happy.
Old Sep 19, 2010 | 09:24 AM
Gone Fishin's Avatar
Gone Fishin
Elvis,
Hate to tell ya, but no vacuum lines for the controls--that would be too easy, they're electric, they're small synchr motors mounted on the hvac housing. I have similar problems with my 2005 occasionally. It seems mine are just kinda sluggish to move but eventually do move. Its frustrating but hasn't pissed me off enough to yank the entire dash out to get to the hvac box
Good Luck
Old Sep 20, 2010 | 11:50 AM
MongoDV8's Avatar
MongoDV8
Thermostat bad. Do you have a temp gage on the dash ? If so what does it read ?
Old Sep 20, 2010 | 12:37 PM
dodgeboy1979
Cool i head by Reddeer all the time my folks live in rocky Mountain House so its basically on the way from Lloyd. Ya we had a few flakes of snow here today hopefully you got the heater fixed lol.
Old Sep 21, 2010 | 09:47 AM
ELVIS56's Avatar
ELVIS56
No snow here yet but you can tell it wants to. I think the problem with the hose was that the truck wasnt right up to temp but warm enough to blow heat as it was coming out of some vents. I was hoping it was vacumm but I went to the dealer to get a new PCV valve ($55. + tax, no thanks) and the parts guy said that there are electronic actuators buried up in the dash and the gears may be bad as I am having this problem intermittently. Theres a good dodge mechanic that all my friends go to here and swear by him so I will also check with him on this. BTW I will check my temp next run out.
