Sick of "ABS" and "Brake" light!
Old Sep 11, 2010 | 08:22 PM
AaronOregon's Avatar
AaronOregon
Default Sick of "ABS" and "Brake" light!
I have researched on here for hours and changed the sensor on the rear diff and cleaned and put dielectric grease on the plugs on the module. Not sure where to go from here? They stay off for a day or two and just come on at random times with no rime or reason. Where are they on the front brakes and are they prone to dirt and corrosion or what? What else do you guys suggest.
Aaron
Old Sep 11, 2010 | 08:42 PM
brettj2408's Avatar
brettj2408
check with a chrylser approved scan tool that will read abs codes. you sure your e barke isnt pulled? or the e brake sensor?
Old Sep 12, 2010 | 07:38 PM
mexico's Avatar
mexico
bump. i have the same issue what is wrong here?
Old Sep 13, 2010 | 05:37 AM
RedTruck-VA's Avatar
RedTruck-VA
I was getting a ABS light when I was using a DSP tuner. Diablo was unable to help and I had to take it to the dealer to have the warning reset. The code I was getting said the ABS system was out synch. My problem was caused by DSP "Quick Tune".
Old Sep 13, 2010 | 11:19 AM
AaronOregon
Mine has done it all along with no tune at all.
Old Sep 13, 2010 | 11:57 AM
runvs's Avatar
runvs
check the wiring also at the sensor in the rear end the wiring is known to break inside of itself, due to heat
Old Sep 13, 2010 | 11:10 PM
HemiRam1566's Avatar
HemiRam1566
my abs light and track control light just came on.. scanned it at work its left front speed sensor erratic performance.. i just ordered a new hub assembly and front brakes i will do tomorrow.... speed sensor in the wheel bearing fu**ed i guess.. hmm go figure a electrical item failing in a mechanical device.
Old Oct 6, 2010 | 12:43 PM
parkmann's Avatar
parkmann
Default ABS and Brake light on
I have the same problem. I got it scanned and was told my master cylinder has a fluid level sensor on it and it has failed. They said I needed a new master cylinder $420 parts and labour (I think I will tackle this myself)
