diablotuner+halolights=worst day of my life!!
Old Sep 13, 2010 | 09:07 PM
akinder09's Avatar
akinder09
Angry diablotuner+halolights=worst day of my life!!
so i order my tuner and lights about a week ago and was so excited to get them and they finally came in today........
but with my luck i hooked up the lights and the halos didnt come on just the regular bulbs.....
so then i thought maybe the red and black wire was the problem so i spliced them to the lights harness and nothing came on.....so i call k2motors and the guy is like uhh idk ill send you some new ones...i wanted help not new ones....
anyone have any idea why the halos wouldnt turn on?......after tht 4 hr adventure...
i thought to myself well i still have my diablo tuner that will be fun...i plug the tuner in and it say your truck needs and update go here www.somethingsomething.com but i had one problem they didnt send me my pc interface cord i ordered.....is there any home device cords i could use?
Old Sep 13, 2010 | 09:27 PM
glass3222's Avatar
glass3222
go to radio shack or walmart and get a serial (rs232) to usb cable. then go here to update you dsp http://www.diablosport.com/index.php...isplay&pid=152
Old Sep 14, 2010 | 12:05 AM
Nate769's Avatar
Nate769
that red and black wire you speak of? You might already know this but the black is the common, red is the 12V
Personally I would just take the black right to the frame of the truck. If there are other ground locations nearby I would go out of the way to get it to there, just eliminates tonnes of grounds everywhere.
Where did you tie the red into exactly? You mentioned that you tied it into in the headlight harness? So if the halo lights up or not depends on where you spliced them in, because I know that one side is for the low beams and the other side is the highs of course. Try turning your high beams on and see if they light...if they do then you would have to bring it to another 12V source. Personally I would just run it right off of a fuse from the fuse box. You don't want to tie it into either side (if you were thinking that) I would not want to take the risk of it being INSTANT 12V off on one side then INSTANT 12 on the other. You might risk blowing up some bulbs. You could take 2 meters to it and see, but i would not take the chance. There are lots of sources in the fuse box, I would go there....
Old Sep 14, 2010 | 01:42 AM
akinder09's Avatar
akinder09
i think the red is for the leds i think the halos should come on when i plug them into the harness...also there is another connector on the back i have no clue what its for...not a connector with wires just like a port you could plug something into...i pm'ed someone with the same ones i have and ill see what they have to say
Old Sep 14, 2010 | 02:45 AM
RedTruck-VA's Avatar
RedTruck-VA
Sorry man, if that makes for your worst day of your life, count yourself very very lucky.....
Old Sep 14, 2010 | 06:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said, to test the halos, take the red and go directly to the (+) on the battery and take the black and go to ground or (-) on the battery. The chances of both sets of halos NOT working is slim. Sounds like you just got them wired wrong.
As for updating the DSP, they tell you on the site it doesnt come with cables and give you the option of buying them. So it is good you seen that and bought one. It sucks they didnt send it. Glass3222 is right on the money. That cable RS has is the one you need and is about $30 bux. I would get Diablo to cancel the shipment of that one and just buy one locally
Old Sep 14, 2010 | 10:54 AM
akinder09's Avatar
akinder09
yeah thts a good idea about testing them and i will see if we have one here at the local walmart but...i live 60 miles from the nearst city so thats a problem haha
also shouldnt there be a red and black for the halos and a red and black for the leds?.......there are two other red and blacks but they go into a battery pack thing and go rite through it and back into the headlights? maybe that is an adapter so you only need one red and one black for both the leds and halos
Old Sep 14, 2010 | 11:45 AM
Marx's Avatar
Marx
not sure if this will help
http://www.youtube.com/watch?v=3e6bOoXGWi4
Old Sep 14, 2010 | 05:13 PM
akinder09's Avatar
akinder09
Originally Posted by Marx
yeah thats exactly what i did i dnt think i connected them very good but now i think ill do it to the fuse box to the parking light fuse
Old Sep 14, 2010 | 09:15 PM
luckydt's Avatar
luckydt
let me know if you need more help with yours. It took me some time to figure how they had wired them. I know you see 4 total wire to black box and only 2 coming out the headlight so you would think that connector is for the LEDs or halos, but its not. Leave that connector undone and hook up the black to ground and the red to your positive wire on the running lights. Also im talking about the red and black wires coming out the back of the headlight. If you do that then when you turn your running lights on you get your halos and the LEDs on.
