fixing roof
Old Sep 19, 2010 | 10:38 PM
Atwiss's Avatar
Atwiss
Default fixing roof
ok so i am gonna fix my roof....
but idk how to get headliner out i have an idea but i dont want to mess anything up and if anyone has some tips about bondo sanding and where to get vin spray paint/cans thanks
ps can someone decode my vin
1D7HA16K24J153130
Old Sep 20, 2010 | 10:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Decoding VIN i cant help with. From the pics I cannot tell if you need to bondo or not but if you do and need help I would hit the bondo and fiberglass forums.
Unfortunately, we do not have a body or sheet metal section here.
As for getting the head liner out, you have to first remove the A, B and C pillars and the the headliner will come down.
Old Sep 20, 2010 | 08:56 PM
Kevno6's Avatar
Kevno6
http://www.automotivetouchup.com/
Never had a problem with their paint matching. The spray can works great. Read up on their aerosols, they have a very fine mist.
Old Sep 22, 2010 | 05:01 AM
nx75080's Avatar
nx75080
Make sure you only put the bondo on bare metal,will not stick to any paint or primer.
And from looking at the pic,it seems like a good size,the best way to go is with a air sanding board.At least 12"-18" in length at least.
If you try to sand the bondo by hand,it will look worse then what you have now lol.
Start with 36grit to knock it down fast and gradually decrease going to 80 then 180.Be prepared to put it on and take it off a few times to get it right.
Use a good building primer on the bondo after to fill in any fine scratches.go from 80grit to 220g,then finish sand with 400g or 600g before paint.
Old Sep 23, 2010 | 09:51 AM
bige2's Avatar
bige2
Not sure about the fixing part, but if you are painting, I recommend www.touchuppaintonline.com. I got paint there twice to paint my fender and spoiler and they matched perfectly both times. I think it's about $20 for a spray can of OEM paint
