Coolant resevoir tank?
Old Sep 22, 2010 | 10:53 AM
Flying Mullet's Avatar
Flying Mullet
The tank on top of the shroud. I know it doesn't get hot hot but didn't want to have it melt whatever I put on there. I thought about the RTV but would that adhear to the plastic/pvc that it is made of? I will give the permatex stuff a try, its been bothering me for a while and I want to take care of it before the winter. Any prep other than cleaning the coolant off that I should take into account so that it bonds properly? Thanks for the help.
Old Jan 29, 2011 | 03:08 PM
glock45's Avatar
glock45
Default Aftermaket or alternative model coolant tank?
Originally Posted by AaronOregon
Where's the best place to get one for a 2002 4.7? Mine is leaking around the filler neck. Thanks!
Aaron
Just wondering if you ever found one cheaper than the $70 dollars that Dodge wants.
Anything aftermarket or from an alternative model?
Mine is leaking (under pressure) from the back of the filler neck and I need a new one.
Old Jan 29, 2011 | 04:20 PM
fewmopar's Avatar
fewmopar
What about using epoxy on it.
Old Jan 29, 2011 | 06:20 PM
chambers's Avatar
chambers
On my 04 the seam where the 2 plastic pieces are pressed together is leaking real slow. Tried jb weld on the whole thing and it still drips like it was before. I just ordered the new revised tank from mopar wholesale, hopefully I won't have to replace it again.
Old Jan 29, 2011 | 10:48 PM
02RamMan's Avatar
02RamMan
Mine was leaking around the top of the tank also, I just used some JB Weld then once it dried i put silicone over it. It may have been overkill, but this is a common problem and the cooling system has 16 psi on it so the glue you use has to be strong.
Old Jan 29, 2011 | 11:18 PM
T-Muns's Avatar
T-Muns
Mine was also leaking at the top where the spout meets the bottle. "Seal-All" worked for me.
Old Jan 30, 2011 | 03:54 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Lots of times you can find used ones on threads where guys are parting out their trucks
Old Jan 31, 2011 | 10:12 PM
glock45's Avatar
glock45
You got a part number on this revised tank?
Thanks in advance.
Old Feb 1, 2011 | 01:25 AM
ramjamhemi's Avatar
ramjamhemi
The best thing to do, but requires some skill is to plastic weld it. You can use a soldering iron by itself if it's a hairline crack, otherwise you would need some filler rod. If you know what material the tank is you can purchase filler rod from places like McMaster-Carr. I've chopped up a milk jug (HDPE) to use as filler for what I think was ABS, and it kinda worked. It's best to match the filler material to what you are repairing if you really want it to work.
If it's a small crack, I would try to use a Dremel to cut a small v-notch in the crack without making a hole in the bottle. I personally would cut off the spout of the overflow, grind it up, and use it as filler material. Clean the area with soap, water, and a final isopropyl alcohol wipe before welding.
Old Feb 1, 2011 | 09:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The problem I see with trying to plastic weld it is the material is so thin already you would likely burn through it.
