tranny problem
Old Sep 27, 2010 | 01:11 PM
grayth_55's Avatar
grayth_55
Default tranny problem
this just started yesterday. my truck shifts real hard when it goes from 1st to 2nd. and a little bit from 3rd to second. i changed my fluid and filter and nothing was burnt and didnt have any metal pieces in the pan. my friend works at a dealership as a mechanic and he works on transmissions and he said that it could be the computer or the shift solenoid which. he said that he could flash my computer and it might fix it. im not really sure and was wandering if someone else might have the same problem.
Old Sep 28, 2010 | 10:03 AM
pjordan4477's Avatar
pjordan4477
Well, tranny work is expensive. I'd let him flash it, it won't hurt anything, just put everything back to default stock settings. If it doesn't work go from there.
Old Sep 28, 2010 | 10:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Are you getting any check engine lights or DTC codes?
Old Sep 29, 2010 | 10:39 PM
grayth_55's Avatar
grayth_55
i got it fixed. it turned out to be a sensor in the shifter. it was causing the transmission no knowing how to shift. it was cheap to and they had to put the sensor in and re flash the computer and re learn the transmisson.
Old Sep 30, 2010 | 06:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Which sensor was it?
Old Sep 30, 2010 | 08:27 PM
Heavy_Sack's Avatar
Heavy_Sack
this is the only tranny problem i have came across
