Failing left turn signal(06 ram 1500)
Old 09-29-2010 | 02:18 AM
Cowherdingjoe's Avatar
Cowherdingjoe
Default Failing left turn signal(06 ram 1500)
Hello, I very recently bought this ram however I cannot get my front left blinker to work properly. Initially the left blinker sounded very fast, and the amber bulb in the front wasn't flashing at all... just the rear.
After replacing the bulb I tried the turn signal again, and this time the front and back signals were flashing much faster than the right side. When I turn on the headlights the new amber bulb fails to illuminate at all on the left side.
Can someone possibly pose a solution to why this might be happening? I love this truck but this issue with my turn signal is driving me nuts. Thank you !
Old 09-29-2010 | 06:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Fast flashing bulb means one bulb on that side is not working or burnt out. So if you have replaced the bulb once and its not working, I would take the bulb from the right side (since you know it works) and put it on the left side and see what you get. If it still doesnt work then go get you voltage meter out and check for voltage on the left side in that bulbs harness. Check the harness for breaks in the wires, corrosion, melting, ECT.
If all of that looks good then you have to start tracing the wires. Do a search here for the Service Manuals I uploaded some time back and use them for troubleshooting since they have schematics in them.
If you are not electrical or mechanical savvy, then now is the time to take it to someplace or someone that can help.
Old 09-29-2010 | 11:09 AM
Cowherdingjoe
Thank you for the suggestions, I'll let you know what the problem was when it's resolved.
Old 09-29-2010 | 03:44 PM
dirtydog's Avatar
dirtydog
Moderate User
Need a year please. They are all different.
Old 09-29-2010 | 04:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dirty, its an 06/1500
its in his title....
Old 10-01-2010 | 08:42 PM
Cowherdingjoe
do i need to repeat myself.
* Problem still isn't resolved as of this point
Quick Reply: Failing left turn signal(06 ram 1500)
