02 quad cab,strange Clunk
Old Oct 3, 2010 | 09:09 AM
steeringcolumn's Avatar
steeringcolumn
Default 02 quad cab,strange Clunk
I have a strange "clunk" somewhere in the drivetrain.It only does it from stop.
I've checked the ball joints and trans mount,seems tight.
The differential was replaced under warranty at about 64K.
The truck now has 125k on it,it just started doing this.
This is an 02 Quad cab 2wd.with the 4.7
A friend said my spare tire was loose,tightened that,still have the problem.
I read through 34 pages looking for a similar problem on this forum to no avail.
Any help would be much appreciated.
Last edited by steeringcolumn; Oct 3, 2010 at 09:13 AM. Reason: left vehicle info off
Old Oct 3, 2010 | 09:21 AM
dirtydog's Avatar
dirtydog
Moderate User
Check to see if there's any play in the u-joints. There shouldn't be any at all.
Old Oct 3, 2010 | 10:28 AM
steeringcolumn
I have checked the u joints and trans mount,both seem tight.
If the ujoints were getting bad wouldn't I have a full time "vibration?"
It doesn't "clunk" when I put it in gear.It only does it from a dead stop
Old Oct 11, 2010 | 07:29 PM
moosefire66's Avatar
moosefire66
Sway bar end links? I had a similar problem, and my driverside endlink is clunking in and out of position.
Old Oct 13, 2010 | 12:52 PM
Greg in MO's Avatar
Greg in MO
I would guess U-joints as well. My '02 just had to get them replaced, although I couldn't feel any play in them, they were visibly shot with a ton of vibration when moving.
Greg
Old Oct 13, 2010 | 01:07 PM
Denniss66's Avatar
Denniss66
i have had u joints that did that from a stop on my chev or if i was going down the highway and i left off the throttle then hit it again they would clunk but never really had a vibration from them that i could feel
