help!!!!!!!!!!!!!2002 1500 problem
Old Oct 3, 2010 | 09:28 AM
mrhoads's Avatar
mrhoads
Default help!!!!!!!!!!!!!2002 1500 problem
i have a 02 1500 with the 5.9 360 and when i start it cold it will run fine for about 3 to 5 minutes then while under load it starts hesitating and running like it wants to die so i stop turn it off and restart it and it seems to run fine after the restart i replaced the cps and no luck still does it, no error codes either im kinda lost on this. anyone with advice on this would b greatly helpful
Old Oct 3, 2010 | 10:09 AM
dirtydog's Avatar
dirtydog
Moderate User
What's the cps? You mean TPS(throttle pos. sensor?)
Or did you intentionally mean the cam sensor? If no codes were thrown, i wouldn't see how the cam sensor would be of issue.
I'll move this to the Tech are for more replies.
Old Oct 3, 2010 | 01:27 PM
mrhoads's Avatar
mrhoads
sorry i meant the crankshaft postion sensor, had a mechanic tell me to change that and see if that was the problem it wasnt though kinda stuck on what 2 do now
Old Oct 4, 2010 | 10:00 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Do you get any CEL's or DTC's?
Old Oct 6, 2010 | 07:11 PM
mrhoads's Avatar
mrhoads
no codes tested fuel pressure this morning right at 50 psi could the problem possible be a o2 sensor i put on a flowmaster cat back system couple of years ago and i had to replace a o2 sensor, just a thought
Old Oct 7, 2010 | 08:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
50lbs is about right from the last srvc man I recently read.
Old Oct 7, 2010 | 11:36 AM
dodgeboy1979's Avatar
dodgeboy1979
sounds like your precat 02 sensor is on the way out, quite often you won't get a CEL from these until they fail. Check your IAC it may need to be cleaned as well.
Old Oct 8, 2010 | 07:27 AM
mrhoads's Avatar
mrhoads
Post
im gonna replace the precat o2 sensor and see if that fixes the prob not 2 sound like a dumbass but what is a IAC thnx for your help guys
Old Oct 8, 2010 | 08:09 AM
mrhoads's Avatar
mrhoads
that would explain the crappy gas mileage ive been getting lately
Old Oct 10, 2010 | 09:40 AM
mrhoads's Avatar
mrhoads
thnx 4 your help guys looks like the precat o2 sensor was the culprit i gained a couple of mpg plus running alot smoother now thnx again
