2002 Dodge Ram 1500 5.9 Exhaust Size
Old Oct 4, 2010 | 07:54 PM
e_red7's Avatar
e_red7
Default 2002 Dodge Ram 1500 5.9 Exhaust Size
Thinking about getting a new muffler and I was wondering what the size of the pipe entering and leaving the factory muffler?
Old Oct 4, 2010 | 08:58 PM
korby05's Avatar
korby05
2.5 inch
Old Oct 30, 2010 | 07:25 AM
brendan quinn's Avatar
brendan quinn
Default proformance & handling2002 5.9
Originally Posted by korby05
2.5 inch
my truck is a 4 dr 5.9 low miles 26000 it is slow as hell at any speed & handles like its loaded with cargo .I brought it to local dealer,sevice manager said he put top tech on it !tech said that it is normal, the handleing & proformance. my son has 2002 4.7 with 260000 mile handles & proformance great . any sugestion?
Old Jan 25, 2011 | 08:15 PM
e_red7's Avatar
e_red7
ok so i got a new muffler
Material: Aluminized Steel Overall Length: 19" Style/Size: 4" x 9" Oval Muffler Inlet Size: 2.25" Muffler Outlet Size: 2.25" Inlet/Outlet Style: Single In / Single Out Inlet/Outlet Location: Offset / Center Body Length: 13"
Its shorter than the original muffler. So I need a connector. Anyone know the diameter I would need leaving the muffler to connect to the 2.5 tailpipe?
Old Jan 26, 2011 | 12:49 AM
spinner01's Avatar
spinner01
What year is it? 26k miles and a 5.9, wow. Did you just get it or has it always been like this? Mine doesn't preform like the Hemi's, but it's no slouch either. If you give a little more info I may be able to help. I love mine ... in fact I've owned two. My first had different gears in the differential and it shot out of the hole like a rocket compared to my current one.
Old Jan 26, 2011 | 06:28 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
2.5 inch
Well if the OEM pipe is 2.5 and you bought a muffler that is 2.25 in and out, then you need 2 reducers that go from the 2.5 pipe to the 2.25 inlet and outlet of the muffler.
Old Jan 26, 2011 | 06:46 PM
e_red7's Avatar
e_red7
My bad.... my muffler is 2.5 entering and leaving. So since the OEM pipe is 2.5 would I still need 2 reducers?
Old Jan 26, 2011 | 10:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
No. You would need two 2.5" couplers to slip over the pipe and muffler inlet /outlet so they can be welded
