Just got my 04 dodge ram w/Hemi. What Oil is to be used? 5-30?
I have used mobile 1 full synthetic since day one. I get Mobile 1 at wal mart as you can usually get 5 quarts for what 4 quarts cost at advance/autozone. Then I usually pick up a mobile 1 filter from advance/autozone as they dont carry them at wally work.
Either way, im at 120K miles and the truck runs like the day it was born. Just switched to mobile 1 high miles. I am noticing my truck is starting to burn about 1.5quarts in between 4K mile oil changes. Over all, I think if you just maintain it you will enjoy the hemi for a long time!
5/30 up to '04, starting in '05 they call for 5/20. I can understand the switch for the '06+ MDS trucks, but can't for the life of me figure out why the change for from '04 to '05. The trucks are identical save PCM tuning.
I run 5/20 in my '04 but run a cooler thermostat than stock, so I opted for the slightly thinner oil. Use 5/30, but if you can't get it, IMO you'd be fine with 5/20 as a secondary option...
I switched to 5w20 for the better gas mileage. At bobistheoilguy.com they say that the difference is negligible. I have also noticed that my engine is noisier. I have the hemi tick which makes it sound like a diesel engine. From what I've heard at this site, a thicker oil helps keep things quiet. Also, pennzoil platinum and royal purple synthetic are both good at keeping that hemi tick at bay. Mobil one is said to make it noisier for some reason. Unless you have a good reason I would stick to 5w30.
Trending Topics
