4x4 transfer
4x4 transfer
So I was reading in my manual that its ok to transfer from 2 high to 4 high while in motion. The Manual says that you can do it up to about 60mph. I always thought that you had to be in neutral and at a stop to put it in 4x4. My question is, will it damage the transfer case or motor or tranny by switching while in motion or is it better to just do it when at a stop?
I have an automatic tranny with manual 4x4 on the floor if that makes a difference.
My manual says that I don't have to slow down to switch from 2wd to 4wd lock. Switch from 4wd lock to 4wd low preferably should be made on stopped vehicle. Of course there is several rules when you engage 4wd. I assume writers of this manual got an instructions what to write from engineers :-) so most likely it is safe.
Jake, Yes its the same for electronic 4wd. Only difference between the Manual transfer case and electronic is the push button uses a motor to move the mode fork while the manual uses you to move the mode fork.
Slava, You don't have to slow down, Just be on a coast for the second it takes to switch. Accelerating while shifting to 4hi is a great way to end up replacing the transfer case among other things. Transfer cases in these trucks are definitely not the most stout out there.
