Proper enging temp??
oil is sumped in the bottom part of the motor as in the oil pan. but is ran through ports on the crank, sits on the cylinder walls, etc
coolant is ran through the block and the head where as in the hottest part of the engine is because of combustion, combustion happens in the top part of the engine
thats the main reason why you would have different temps
it will also matter if you have the tow package factory on your truck with an oil cooler.
