exhaust smaller than stock?
Old Oct 11, 2010 | 07:53 PM
rickof08's Avatar
rickof08
Default exhaust smaller than stock?
So I actually crawled under my truck today and saw that the exhaust shop put smaller piping than what I told them to. They welded a 2.5in pipe on my stock 3in. So my cherrybomb is actually a 2.5in and 2.25 dual out. Will this cause any long term problems or will it be fine? If not im going to another shop to do a 3in. Also the piping is crush bent not mandrel, so at the skinniest point its 2in.
Old Oct 11, 2010 | 08:53 PM
traker1001's Avatar
traker1001
SIDO or DIDO? Was your Muffler a 2.5" in or 3" in, If it was 2.5" in they would have had to reduce it.
To answer your main question, Yes I think it will make a difference, although, minor. The stock muffler vs Aftermarket will mostly negate that though.
Old Oct 11, 2010 | 08:56 PM
rickof08's Avatar
rickof08
ITS SI/DO and the pipes going out are crush bent. also none of the pipes are lined up correctly they go into the stock pipe at a slight angle.
EDIT: the muffler is 2.5in 2.25 out
Old Oct 12, 2010 | 04:15 AM
RedTruck-VA's Avatar
RedTruck-VA
Did the shop provide the muffler? If they did and it is the wrong muffler, I would have them correct it. If you supplied the muffler and simply don't like the work, then I would find a new shop and do the whole thing again. Believe me finding shops doing anything right is a challenge. Good luck....
Old Oct 12, 2010 | 04:36 AM
rickof08's Avatar
rickof08
They supplied the muffler. Sadly, I told them to do 3inch but didnt get it in writing Mainly I just want to know if this could damage anything. The truck isnt stock and I use it to tow so I want everything to be at its best. You get what im sayin?
Old Oct 12, 2010 | 08:53 AM
HammerZ71's Avatar
HammerZ71
The 2.5" muffler to dual 2.25" isn't that big a deal, I'd be much more concerned about crushed down bent pipes at 2" though.
Sounds to me like you got a "rush in/rush out" bargain basement job...
Old Oct 12, 2010 | 09:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah I agree. But if I said i wanted 3" then there had better not be anything on my truck smaller than 3". I dont care if it was in writing or not. If that was what was discussed and agreed on, then thats what it should be.
Old Oct 12, 2010 | 11:49 AM
08XDakota's Avatar
08XDakota
If anything i would just get mandrel bent pipes in their, but that's just me lol
Old Oct 12, 2010 | 04:09 PM
That1guy's Avatar
That1guy
I would take it back and have them redo it.
Old Oct 12, 2010 | 06:26 PM
chambers's Avatar
chambers
I doubt it will do any damage, maybe you lost a little power. Like Weed and others said take it back and have them line everything up properly and get the 3" pipe and muffler. Mandrel bent will likely cost you more, that's up to you if you want that.
