fresh rebiult 4.7 with codes 300 miles away from home
Old 10-16-2010 | 10:50 AM
EvlKenevl's Avatar
EvlKenevl
Default fresh rebiult 4.7 with codes 300 miles away from home
picked up my 02 4.7 1500 yesterday
Truck ran strong to jobsite untill last 5mins. it bucked and engine light came on. made to my jobsite checked codes (p0301,p0302,p0320) I know what they are and am hoping its a easy wiring fix.
if anyone has had this issue i can really use your help right now!
thanx in advance
K
Old 10-16-2010 | 11:27 AM
dirtydog's Avatar
dirtydog
Moderate User
first 2 are misifre codes on cylinders 1&2
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
Id say the problem is the P0320. make sure the connectors are tight and not chaffed.
Old 10-16-2010 | 11:40 AM
TRXHemi's Avatar
TRXHemi
Rich, you are just a plethora of info....
Old 10-17-2010 | 08:33 AM
EvlKenevl's Avatar
EvlKenevl
Mistake on codes 0301 and 0303
Should have typed 0201 and 0203
0320 is still coming up and I don't know what's causing it
Old 10-17-2010 | 09:02 AM
HammerZ71's Avatar
HammerZ71
0320 is usually a loose wire, but could also be caused by a cracked wire that is arc'ing.
Old 10-18-2010 | 09:33 AM
EvlKenevl's Avatar
EvlKenevl
Thanx HammerZ71, I see your input all over this site and find it very informative.
talked to engine rebiulder this morning and he thought the crank sensor was iffy,but cleaned it up and installed it anyway.
I'll pick 1 up today after doc's appointment. my fiancee is pregnent!
Quick Reply: fresh rebiult 4.7 with codes 300 miles away from home
