power window problem
Old Oct 22, 2010 | 10:33 PM
Denniss66's Avatar
Denniss66
so to get the switch apart get all the screws out and pop off the window switch covers. i used a set of needle nose pliers to do it and they are hard to get off.
this is what it will look like then just take it apart
this is the switch that needs to be fixed take the plastic piece of the top of it
stretch this spring out a little bit so it pushes the window switch up harder.
with a flat screw driver and the white window switch piece back in bend out the prongs a little bit. don't go too crazy but when you let go of the white switch after pushing it down it shouldn't come out of the thingy without having to pull it out past the prongs.
make sure that this little spring goes back in right before putting it back together there is a little hole that the bottom end of the spring goes into.
i would suggest pluging the circuit board into the truck before assembling to see if it works or if the prongs need to be bent out more.
Old Oct 23, 2010 | 08:45 PM
truegent81's Avatar
truegent81
nice work! appreciate the pics as well. i can't wait to try this later on this week. hopefully by tuesday, i can roll the windows down from their respective location.
Old Oct 25, 2010 | 11:36 AM
tomtahoe's Avatar
tomtahoe
Default Cheap Power Window fix
Mine had the same problems others describe here with only the driver door controls making all the other windows operate but not the other individual door windows. I took my driver side door module out and started jiggling large yellow wire while wife held passenger door window switch in down position. It worked intemittently. Decided to bypass power window lock switch by jumpering between tan 12V power wire on Connector 1 and large yellow power wire on connector 2. Works perfect and is a cheap fix but power window lock function is disabled. I don't care about this since I don't have kids.
Old Oct 26, 2010 | 09:47 AM
wills03's Avatar
wills03
That's a great DIY. I will have to give this a try.
Old Oct 26, 2010 | 12:29 PM
truegent81's Avatar
truegent81
to remove the plastic switch covers is a bitch. i was afraid something was going to snap. question now is, after removing the 6 screws, what is the best way to separate the two plastic pieces? the only thing i have left on top is the L and R toggle switch....tia
NVM...i started at the top and started just to pry it apart. once you get the top apart, just slowly walk your fingers around prying it open...
Old Oct 26, 2010 | 12:53 PM
truegent81's Avatar
truegent81
this little ****ing spring is a bitch!!!! what is the best way for it to stay while putting black box cover back on? nand there is no hole it goies into. it runs ib the littlre track..
Old Oct 26, 2010 | 01:06 PM
truegent81's Avatar
truegent81
Old Oct 26, 2010 | 01:09 PM
Denniss66's Avatar
Denniss66
you can see that the bottom part of the spring not the one that runs in the track but the other part has a little hole where it should go into its hard to see but should be able to notice it from the picture its kind of a pain to get back in.
Old Oct 26, 2010 | 01:12 PM
Denniss66's Avatar
Denniss66
the arrow points to where the bottom part of the spring goes
Old Oct 26, 2010 | 01:15 PM
Denniss66's Avatar
Denniss66
remember to try the window switches out once you get that cap on before putting the window switch covers back on.
