power window problem
Old Oct 26, 2010 | 01:15 PM
  #21
truegent81's Avatar
truegent81
theres no point to thuis spring...**** it...what could happen if iu dont put it back in? its git the civer to hold it
Old Oct 26, 2010 | 01:17 PM
  #22
truegent81's Avatar
truegent81
yeah foud the hole..i get the spring set up, but when iu go to cover with the box cover it comes out
Old Oct 26, 2010 | 01:18 PM
  #23
Denniss66's Avatar
Denniss66
huh never really had that problem i just stuck it where it goes and put the cover on it never gave me any grief
Old Oct 26, 2010 | 01:23 PM
  #24
truegent81's Avatar
truegent81
when yu bent the prongs, how high did the white piece come up? if your saying you never had this problem, your white piece must be sitting pretty low now...i bent the prongs so the piece wouldnt come out, but it still comes up as high as it can without coming out
Old Oct 26, 2010 | 01:28 PM
  #25
truegent81's Avatar
truegent81
can i test it without it put togetrh? it still looks like a circuti oard. if i test it like this will it mess up anything?
Old Oct 26, 2010 | 01:33 PM
  #26
truegent81's Avatar
truegent81
WHOO****INGHOOO!!!!!!! it works, windows all work now. thanks to denniss66 for the DIY. but this is a pain the *** working with small pieces. if you can deal with rolling down other peoples windows go for it bc this sucked. took me 2 1/2 hours
Old Oct 27, 2010 | 08:10 PM
  #27
RamTracks02's Avatar
RamTracks02
I did everything shown above and i still have the same problem. It is intermittent and seems to be a loose connection somewhere. When i tested the switch prior to reassembling, it worked fine. When i put it all back together... nothing! I wiggled the harness and it worked again. It seems that it could be the connector on the circuit board. Maybe the connector has a bad connection where it attaches to the board. The wiring side of the harness appears to be in good condition and has no signs of corrosion or bad connection. I even put dielectric grease on the plug and used a screw driver to close the female terminals for a tighter connection onto the switch. Any other suggestions? Besides buying a new switch lol.
Old Oct 28, 2010 | 08:14 AM
  #28
tomtahoe's Avatar
tomtahoe
Default Power window lock bypass
Try what I said above " bypass power window lock switch by jumpering between tan 12V power wire on Connector 1 and large yellow power wire on connector 2. "
Old Oct 28, 2010 | 11:15 AM
  #29
RamTracks02
I like your idea... There is really no reason i would ever need to lock my windows. I might give it a try. What is the best way to jump these wires? Could you use those easy splice connecters that you just push onto the wires, then put a short wire between them? Any other suggestions?
Old Oct 28, 2010 | 01:46 PM
  #30
tomtahoe's Avatar
tomtahoe
Default Jumper wire
Yes this will work. Recommend similar wire gauge to the tan and large yellow wires for jumper wire. Real easy fix.
