Rear driver Side Window wont go up!!!!
Old Oct 21, 2010 | 04:28 PM
bateboy89's Avatar
bateboy89
Default Rear driver Side Window wont go up!!!!
How do i manually put the window back up till i can get it fixed? need help ASAP!!!
Old Oct 21, 2010 | 04:29 PM
bateboy89's Avatar
bateboy89
its a 2006 2500 4 dr.
Old Oct 21, 2010 | 04:46 PM
9511234's Avatar
9511234
Going to have to take the door panels off and tape her up.
Ususally there are a couple screws on different spots around the door. Sometimes they use different methods of hiding them.
Sometimes you can put a block of wood or something in place to hold it up, but tape usually works best -- sucks to have to take it back off.
Can you see any of the window? Did you check your fuses? Did you hear any breaking noises or did it slide down into the door?
Old Oct 21, 2010 | 04:48 PM
bateboy89's Avatar
bateboy89
i got it held up with a pair if vise grips. thanks. i think it needs a new motor/regulator. all fuses and electric are fine
Old Oct 21, 2010 | 08:08 PM
brettj2408's Avatar
brettj2408
test for power at the actuator switch to make sure all your wiring is ok.
