WTF Crazy Rattling STILL
Old Oct 24, 2010 | 02:13 PM
dirtydog's Avatar
dirtydog
Moderate User
So you dont think your wiper motor could be loose causing your problem?
Old Oct 24, 2010 | 02:35 PM
Matt99's Avatar
Matt99
umm ill look at that tomorrow dirty, sorry to skip over that but its the most work to check and I have a big test tomorrow and am studying
is taking the cowl off the only way to check????
Old Oct 24, 2010 | 02:48 PM
oefootball_70's Avatar
oefootball_70
maybe its a wheel spacer. Idk, tossing ideas out there.
Old Oct 24, 2010 | 03:02 PM
nurkvinny's Avatar
nurkvinny
I have the same or very similar noise on mine (06 stock everything). It's very frustrating. After a lot of tightening parts and replacing swaybar links (they were bad), noise remains.
Old Oct 24, 2010 | 03:16 PM
dirtydog's Avatar
dirtydog
Moderate User
Pretty much, unles you can move your wiper shafts around enough that prutrude the colw, but then again, maybe there is something just laying down in there that isn't part of the wiper assembly?
Unless his wheels are loose, i don't think that's the case. Sorta scary if it is.
What about taking off your inner wheeel liner to see if something is touching your fender? There are wires and stff that are roted behind there.
Is it a light hollow rattle like soething light making the noise or is it a heavy souning rattle like it must be a large component?
Old Oct 24, 2010 | 03:37 PM
Matt99's Avatar
Matt99
I checked the wheel spacers...first thing I did lol...i put blue loctite on them and there wasnt one loose
it sounds heavy to me, almost like a piece of heavy metal rattling on another piece of heavy metal. I dont think a video camera would pick up the noise because the exhaust/air intake out be picked up before it. I have been checking everything on the firewall and that I could see
Old Oct 24, 2010 | 08:31 PM
HEMIEMT's Avatar
HEMIEMT
Ok throwing this out there, have you checked your front wheel bearings? I know they mostly roar and vibrate when they go bad. I work part time for a parts store and have had some customers come in with the same symptom and their mechanic diagnoised a bad bearing. never had anyone return the bearings so I am assuming that fixed their issue. May look into that as well if you havent already.
Old Oct 24, 2010 | 11:29 PM
Matt99's Avatar
Matt99
if i lift the tires off the ground there is no play, either 3&9 or 6&12....
its getting worse and I am literally going crazy about this....like i literally am so embarrassed that we crammed into a 2dr coupe tonight instead of going in my truck
Old Oct 24, 2010 | 11:41 PM
oefootball_70
Is it your Fan hitting your fan shroud?
Old Oct 24, 2010 | 11:43 PM
Matt99's Avatar
Matt99
nope i messed around with that a few days ago and theres no way for that to be happening
