Issue with G2 4:56 gears.
Old Oct 25, 2010 | 02:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
NO!!!!!!
NO grinding on the gears. Do not let them RUIN your gears. if they cannot handle it then seal it up and send it someone else to be done correct. Grind and notch ONLY the pin.
Old Oct 25, 2010 | 05:38 PM
BadHab1t's Avatar
BadHab1t
only the pin we all have it done...no issues at all....ill tell you from a gear stand point it will not affect it, but doing the teeth is just stupid.....
Old Oct 25, 2010 | 05:43 PM
oefootball_70's Avatar
oefootball_70
Wow, well.... I think they did my teeth, not the pin....Actually I know they did. So what does that mean for me? I think, I m sure. IDK. Im pretty sure.
Old Oct 25, 2010 | 05:46 PM
HammerZ71's Avatar
HammerZ71
I ain't never heard of grinding the teeth of the gears! and I can't believe G2 would say that. I didn't do my gears myself, but had the install instructions when I bought them and mine are Genuines (now G2), and it said to notch the pin. Or maybe it was the install sheet for the Auburn that said it, I can't remember, but I do remember it said to grind the pin...
Old Oct 25, 2010 | 07:00 PM
BadHab1t's Avatar
BadHab1t
I knew I had to grind the pin so did my tech
Old Oct 25, 2010 | 07:47 PM
jonathanjkb's Avatar
jonathanjkb
here are the two email responses i received from G2, excluding their names.
1. Hi Jonathan,
In many cases it is necessary to grind a tooth or two to get the cross shaft
back in the carrier. What you will need to do is grind the inner part of
the ring gear directly in front of the cross shaft hole on the carrier, not
the whole tooth but where the shaft makes contact. Some people say to grind
the actual cross pin but we don't recommend it as it makes the pin weaker.
The ring gear has plenty of teeth on it and the grinding of a couple of
teeth will not affect its strength. If you have any other questions fell
free to let us know, Thanks
2. Hi Jonathan,
Due to the thickness of the 4.56 gear of the Chrysler 9.25" application,
some material will need to be removed off of the ring gear. This is to
allow clearance for the cross shaft, and is done by grinding the tip off of
a couple of teeth on the ring gear. This will not affect the strength of
the gear in any way, as long as your mechanic does not grind too far into
the tooth contact area.
Either way, all the information from you guys has been more then helpful. Thanks
Old Oct 25, 2010 | 10:54 PM
RedTruck-VA's Avatar
RedTruck-VA
1. Hi Jonathan,
2. Hi Jonathan,
I read this is the recommended method of install and the acticle showed pictures of the ring gear that was ground. They grind the tooth inside the tooth pattern and it doesn't affect the strengh of the ring. Those running differentials other than Detroit and had 4:56 installed may find many more with the ring gear ground than the pin if the installer followed the instructions.
Old Oct 26, 2010 | 03:10 AM
abarmby's Avatar
abarmby
Look here......http://www.ringpinion.com/TipOfTheDay.aspx?TipID=7
So Randy's Ring and Pinion do this as well.
I've also got a reply from a company http://completeoffroad.com who make a "notched pin" as well.
Read here ......
Dear sirs.
May I please enquire if this pin is necessary to install 4:56 gear set in the rear of my vehicle stated above?
I have at present 3:55 stock gear set in place but upgraded the stock Dodge lsd a while back with a Detroit True Trac.
Also, do you ship to England?
Many thanks for your help in this.
Mr A Barmby
Reply....
Jered @ Complete Off Road
10/25/2010 08:49PM
Yes, you will need this pin. Also, we do ship to England. The cost of shipping is $15. If you are interested, we can send you a Pay Pal invoice just provide us with your Pay Pal email address.
Thank you,
Complete Offroad
So to answer RedTruck-VA;s reply, to fitting gears to a DTT rear and not needing a "notched pin"......I'm in a bit of a conflict now?
I suppose this company wants to sell it's notched pin......but would they really suggest buying this if it wasn't necessary?
Sorry for a bit of a Jack to this thread.....but I think it's all good info about this issue?
Al.
Old Oct 26, 2010 | 08:00 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This is directly from www.motivegear.com
CHRYSLER
PROBLEM: CHRYSLER: 9.25", 12 Bolt Cover, 4.56 and Higher.
I bought 4.56 gears for my 1/2 ton pickup, but I cannot get the cross pin into my carrier.
SOLUTION:
It does not matter whose gears you use. You will need to modify your cross pin to use a 4.56 or higher gear in your vehicle. This applies for open differential, Auburn and Eaton differentials. The pin will need to be cut at an angle opposite the bolt hole. Because every manufacturer is different, no measurement is provided.
Old Oct 26, 2010 | 08:02 AM
HammerZ71's Avatar
HammerZ71
Tell 'em Weed... LOL..
