Bosch O2 Sensors
Old Oct 26, 2010 | 10:29 AM
rengnath's Avatar
rengnath
Default Bosch O2 Sensors
Hey guys,
I just ordered 4 Bosch O2 sensors for my Dakota, and since they were Bosch I figured I would have no problems because its a decent company, IMO. Now after reading more about them, it appears some guys have problems with them in Chryslers while others dont.
Has anyone used Bosch O2 sensors on their Dodge (4.7 or 5.7)? Any issues or did everything work out? Just doing some research before I install them so I know if I should return them or not, and not many 3rd gen Daks have replaced the O2s so I decided to ask over here.
Thanks.
Old Oct 27, 2010 | 07:33 PM
JonnyBlaze420's Avatar
JonnyBlaze420
I just repalced my rear passenger side o2 sensor with a Bosch one and havent had a problem yet. Ive always had good luck with them.
Old Oct 27, 2010 | 07:56 PM
2006RAMHEMI1979's Avatar
2006RAMHEMI1979
Is it an easy install? I have a new o2 sensor on the way.
Old Oct 27, 2010 | 08:03 PM
JonnyBlaze420
Hardest part is unthreading them from the exhaust pipe. That is a PITA. There in there good. . The front two arent very easy to get to.
Old Oct 27, 2010 | 08:39 PM
rengnath's Avatar
rengnath
Thanks for the response, Jonny. Hopefully it all works out.
Old Oct 28, 2010 | 08:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I use a 3/4 wrench and a rubber mallet and with one good hit I can pop mine loose
Old Oct 28, 2010 | 08:59 AM
rengnath's Avatar
rengnath
Should I bother picking up the proper O2 socket? Will it make it easier or not really? I doubt I will be able to use a breaker bar regardless due to space constraints.
Old Oct 28, 2010 | 09:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
See if you can get it with the 3/4 wrench first and then go from there.
Old Oct 28, 2010 | 10:42 AM
rengnath's Avatar
rengnath
Sounds good. Thanks weed.
Old Oct 28, 2010 | 06:42 PM
MeTaL's Avatar
MeTaL
I've actually had problems with Bosch O2's. I had to get OE ones from the Dealer to fix my problem....
P.S. I have LT Headers so I'm not sure if they played a part in that, but I haven't had a problem since I changed to OE ones.
