Differential Leak
Old Oct 31, 2010 | 09:20 PM
TRXHemi's Avatar
TRXHemi
Default Differential Leak
So, I have a leak where the drivshaft meets the rear diff. You can tell it's leaking, but it is not dripping. How bad is this?
And is it covered under the powertrain warranty? Thanks.
Old Oct 31, 2010 | 09:40 PM
bigdaddyII's Avatar
bigdaddyII
Its the pinion seal. I would think it should be covered by warranty, dont know about just powertrain warranty though.
Old Oct 31, 2010 | 10:56 PM
TRXHemi's Avatar
TRXHemi
Truck has 57K miles on it.....so out of the regular warranty....
Old Oct 31, 2010 | 11:01 PM
dirtydog's Avatar
dirtydog
Moderate User
No warranty. Not considered a Powertrain item.
It's a $4 seal. make sure you get the double lip seal through NAPA as there are both single and double.
HERE is how you do it.
Old Oct 31, 2010 | 11:30 PM
Matt99's Avatar
Matt99
my dealer said they all leak, but they lie also
mine is ALWAYS covered in old oil but I never see any fresh oil
Old Nov 1, 2010 | 06:19 AM
abarmby's Avatar
abarmby
No....they don't all leak.
They only leak when they are worn.
I'd keep away from that dearlership!
Al.
Old Nov 1, 2010 | 06:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dirty covered it pretty good. Not any more to add. I need to do mine one day soon also though.
Old Nov 1, 2010 | 03:47 PM
TRXHemi's Avatar
TRXHemi
Thanks for the assistance guys....
Not sure I will tackle this myself though.
Old Nov 1, 2010 | 05:53 PM
dirtydog's Avatar
dirtydog
Moderate User
It's very easy. The hardest part is getting the driveshaft bolts off! You don't even have to lift the truck up!
The old seal you can pry right out with a screwdriver.
I've seen a few garages take an impact gun to the pinion nut. I swear half don't know what they are doing!
Old Nov 1, 2010 | 06:00 PM
jbrowder's Avatar
jbrowder
I had the same issue with the pinion seal leak. I was a little hesistant to do it myself, I didnt want to tighten it up too much and have a grinding noise or differential failure as a result. I decided to take it to the dealer. They charged me $145 for the parts and labor.
