Please Help; Steering Clunk!
Old Nov 2, 2010 | 09:02 AM
jimfed67's Avatar
jimfed67
Unhappy Please Help; Steering Clunk!
Guys,
I drive a;
2005 Dodge Ram 2500 Quad Cab, 4x4 Laramie with the 5.7L Hemi.
The problem;
When I have my wheels turned left or right and am in motion, 10mph. I hear and feel CLUNKING coming from somewhere underneath. The closer I get to full lock, the more pronounced. In addition to the clunking, I hear squeaking at low speeds when the wheels are lightly turned and the truck is in motion...
Any ideas???
With appreciation,
Jim
Old Nov 2, 2010 | 11:45 AM
Blacksport's Avatar
Blacksport
Could be your CV joints...maybe check and see if one of the outer or inner boots are ripped. Someone else can chime in...
Old Nov 2, 2010 | 11:51 AM
abarmby's Avatar
abarmby
Yep....if he's 4wd....CV's and the squeeky is the boots probably rubbing.
Al.
Old Nov 2, 2010 | 04:40 PM
jimfed67's Avatar
jimfed67
Unhappy CV Joints?
Does a 2005 Dodge Ram 2500 4x4 have CV joints?? My research says U Joints. Where are the U-Joints located? Does anyone know? Are signs of wear/failure visible or is it something a qualified mechanic will have to diagnose??
Thanks again guys!!!
Old Nov 2, 2010 | 04:53 PM
HammerZ71's Avatar
HammerZ71
He ain't got CVs, he's a 2500 = SFA.
U-joints are possible could also be ball joints, but the Dodge SFA trucks suffer from a steering box flaw, although it's usually accompanied by vibrations at speed.
If it's the steering box, there is a fix:
http://www.genosgarage.com/products.asp?dept=142
Old Nov 2, 2010 | 04:55 PM
abarmby's Avatar
abarmby
Didn't see the 2500 part.
My bad. Still half asleep i guess ha ha ha.
Al
Old Nov 2, 2010 | 06:09 PM
Blacksport's Avatar
Blacksport
I guess I need glasses as well!
Old Nov 3, 2010 | 12:52 PM
jimfed67's Avatar
jimfed67
Default Has anyone experienced this issue??
How bad did the fix set you back financially???
Old Nov 3, 2010 | 01:56 PM
dirtydog's Avatar
dirtydog
Moderate User
^^ No one here had the fix they were just pointing you in the right direction. Unless i missed something?
Cuz everyone posted has a 1500.
clunking..sounds like your steering intermediate shaft is worn..common issue
otherwise, the steering box as Hammer stated which dodge has done recalls for, but not on all years???
Squeaking can be from dry balljoints. I'd say it's your tierod ends that are squeeking. i don't know if they are greaseable on the 2500's as all 1500's are non greasable and that is what i have.
Old Nov 3, 2010 | 03:32 PM
jimfed67's Avatar
jimfed67
Default Squeaking
The squeaking is more like angular or rotational, as the wheel is rotating I'm hearing what I can only describe as a squeak..... Not to be confused with turning the wheel left or right, I don't hear any noise when I do that..
Thanks for the help guys!!
