5.7 hemi will not start in cold
Old Nov 7, 2010 | 07:45 PM
gkemo's Avatar
gkemo
Default 5.7 hemi will not start in cold
I have a 2004 2500 qc dodge laramie wit a 5.7 hemi. I have begun having problems with it starting when the temperature falls. Below 40 it cranks and eventually starts. Below 30 it will not start at all. I have replaced the coolant temp. sensor and the iat sensor. I have cleaned the intake with no change. I took a blowdryer and heated the ETC a little and it started immediately. I have read on some of the forum threads that indicate it could be the battery but I'm not so sure. Why did warming the ETC make a difference? I am from southern WV and our Temps are doing good to make it out of the 50s in the afternoon. Any info would be greatly appreciated.
Old Nov 7, 2010 | 08:23 PM
terracedean's Avatar
terracedean
well you can eliminate your battery preety easily just take it to wal mart or a shop and get them to test it, your cca's(cold cranking amps)# is listed on your battery and could be low wich could be your problem, theyll be able to tell you if its good or not
Old Nov 7, 2010 | 08:37 PM
gkemo's Avatar
gkemo
Thank you for your reply. I will do just that. I hope that is all that it is. I am not much on mechanic work but I do some. My brother is the mechanic but he is still trying to figure this out too.
