Now its the PCM!!
Old Nov 11, 2010 | 03:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
hmm.....wonder if i could get an 05 that way?
Old Nov 11, 2010 | 03:42 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by sinus19
where is the block coolant temp sensor?
One sensor is behind the alternator which should be the coolant temp sensor that feeds your cluster and the other is just above the oil filter on the front side of the block which should feed your ecu. There are 2 sensors near the oil filter. The one that is 1inch above is your oil sensor which faces the pass tire and the other is screwed into the face of the block 4" above the filter.
Pretty sure that's what that sensor is for.
Old Nov 11, 2010 | 06:53 PM
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by OlDirtyJohn
yup, solopcms.com is the ****. i got one from them. it comes programmed and ready to go. they are super professional. within 1 hour of placing my order they called and verified all the info they needed (vin and mileage) and had it out to me the same day.
Glad they worked for you. I emailed them twice asking what kind of turn around time I could expect if I sent them my PCM and didn't even get a response. WTF?
Old Nov 11, 2010 | 06:57 PM
OlDirtyJohn's Avatar
OlDirtyJohn
that sucks, maybe things have changed with them since 2007
