Last edit by: IB Advertising
Browse all: Lighting Guides
- Dodge Ram 2002-2008: How to Install HID Headlights
Step by step instructions for the do-it-yourself repairs
Got *HID* Problems? Check in here...
#542
Need help from the Gurus....
This is a long, long, thread... And I am not sure exactly where my problem lies, but expect it is the TIPM
I have a 2009 Ram 3500 diesel
I have had a "DIGITAL HID" bixenon setup installed and working since I purchased the truck 2.5 years ago that was supposedly designed for the CANBUS system. It is the setup with a relay and a resistor. It is plugged into the driver side only, with passenger side left unused. I do not believe I have any resistors. A detailed link to my install can be found here:
It worked flawlessly until 2 days ago. I no longer have low beams, but still have High Beams on both sides.
Here are the questions:
1) is resetting the tipm by unplugging the negative battery cables for 30 minutes likely to fix my problem?
2) If not, what do I do to fix the problem?
Help much appreciated.
Jon (Utahrd)
Jon (Utahrd)
#543
#546
HID Issue
Ok I have posted a problem using the reply button since I cannot find the thread to start my own question before and no one has even tried to give me a heads up with my problem so here it is again. I have an 04 Durango with the 5.7L in it and I am very adept with mechanics. My problem is that every time I try to connect my HID harness to the truck for some reason the HID lights do not turn off once I turn them on. I have contacted the Dodge dealership up here to see if I could get them to use their starscan to turn off the DRL since the Haynes book pissed me off and only described the DRL and not showed me anything related to replacing the DRL module or what not and they said they didn't know what the hell I was talking about. I have tried different combinations with the setup with no luck. I have checked the ground, got a new relay and harness and still the lights will not turn off. I have checked everywhere I can think of on the net and there is literally no one that has ever dealt with my problem let alone know where the damn DRL module is (If I even have one since I live in AK but the truck might have been Canadian). So I ask if anyone has any ideas please contact me, I am at my wits end and about to just throw the kit away because it has pissed me off for about 6 months now and I would really like to have my HID headlights to go along with my HID fog lights (That I had 0 problems with on the very first time I installed them) If anyone reads this and would rather email me instead my email address is Ryu_Hyabuza@yahoo.com.
#547
#548
