I have a leak on the rack and pinion
Old Nov 10, 2010 | 07:55 PM
caddy244's Avatar
caddy244
Default I have a leak on the rack and pinion
The circled area in the picture is where its leaking, do I need a new rack and pinion? Or what could I do about this? =O
Old Nov 11, 2010 | 05:09 AM
RedTruck-VA's Avatar
RedTruck-VA
Fairly common problem, usually leaks at the boot. Mine will leak occassionally when it sits for long periods. I top it off and so far it stops when I start driving it again.
Old Nov 11, 2010 | 07:02 AM
caddy244's Avatar
caddy244
The steering feels loose and sometimes catches cracks in the road and makes the truck weave. What could it be?
Old Nov 11, 2010 | 07:51 AM
RedTruck-VA
Mine drives normal.
Your's sounds like it is truely damaged. I think I would closely inspect and repair it before driving it anymore.
Old Nov 11, 2010 | 08:00 AM
loflyer2's Avatar
loflyer2
Are the steering problems the result of low fluid?
Old Nov 11, 2010 | 08:09 AM
RedTruck-VA
There are folks here that have replaced their rack&pinion because of various issues. All I have had was the occassional leak. Speaking for myself I think a seal gets hard when it is cold and the flud leaks, My truck doesn't get driven over the winter months and the leak has been in the spring when I first go to start it.
Old Nov 11, 2010 | 10:00 AM
drewbie00's Avatar
drewbie00
My truck just started leaking from around there as well. I cleaned it up last night and tried turning the wheels to get it to leak, but nothing. So letting it sit in the garage to see if any more leaks. I don't have the steering problem like op said.
Old Nov 11, 2010 | 02:37 PM
05220713's Avatar
05220713
I had a leak in the same are last summer. Took it into dodge for an oil change, 1st dealer change in 2.5 years so they couldn't say I never had the truck in for service, and asked them to check out the R&P due to a suspected leak at the same time. I fully expected them to say it was normal but they confirmed there was something wrong and replaced mine. Much to my surprise there was no hassle under the 3/36 warranty.
On a side note my truck did sit for almost a year while gas was close to $4. Bought a Saturn for $800.00 that got 35+ MPG for 60 mile commute and only drove truck every other weekend or so. RedTruck-VA may have something with these leaking after sitting for a while.
