where to put cables through the firewall?
Old Nov 12, 2010 | 08:59 AM
birddseedd's Avatar
birddseedd
Default where to put cables through the firewall?
HI,
iv got an 04 ram 1500. where is the best place to run the plow control cables through the firewall.
the controller itself will be placed next to the 4x4 shifter.
thanks
Old Nov 12, 2010 | 09:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There is a grommet above the brake pedal assembly.
Old Nov 12, 2010 | 04:14 PM
OklaHemi's Avatar
OklaHemi
thats where i ran my amp power wires through
Old Nov 12, 2010 | 07:59 PM
MikeHTally's Avatar
MikeHTally
What he said. Inboard of the brake booster and up a bit is a six-sided plastic plate (it's where the clutch pedal linkage would run). Very easy to drill holes in to run cables/tubing.
Old Nov 12, 2010 | 09:01 PM
Geezir's Avatar
Geezir
There are lots of open areas that you could drill through the firewall if your plow cables are too big to fit through any existing grommets.
I'm running my plow cables tomorrow so I'll let you know how my experiences go.
What kind of plow are you running?
Old Nov 13, 2010 | 06:36 AM
birddseedd's Avatar
birddseedd
i appriciate it. im running a conventional western plow.
Old Nov 13, 2010 | 07:58 AM
Geezir's Avatar
Geezir
so the wiring harnesses aren't that much different then my Boss V-Blade.
I'll let you know how it goes.
Old Nov 15, 2010 | 06:32 PM
Geezir's Avatar
Geezir
Pop off the plastic filler piece where your slave cylender would be and drill it out, feed your wires,add your grommet, and call it a day. Worked great.
As for the push bracket and bracing....if you're doing that yourself good luck. Succession of 8 bits to get through the frame from the pilot hole to the proper 5/8" hole. That frame is made of some hard steel!
Old Nov 16, 2010 | 07:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Trust me, i am running 2/0 welding cables as my power wires to my amps. There is lots of room.
Old Nov 16, 2010 | 02:08 PM
OklaHemi's Avatar
OklaHemi
that is some big *** wire weed. i thought my rockford fosgate 4/0 was big
