My Truck and the Transmission Mod
Old Nov 18, 2010 | 04:35 PM
The Cank's Avatar
The Cank
Default My Truck and the Transmission Mod
My 03 has 83k miles on it. Do you guys think that is too many miles to do the Transmission wire Mod ? I don't want to go buying a new tranny.
Old Nov 18, 2010 | 05:27 PM
mike_r's Avatar
mike_r
It's never too late to mod!
Old Nov 18, 2010 | 05:52 PM
rtmtrrdr's Avatar
rtmtrrdr
what's the transmission wire mod?
Old Nov 18, 2010 | 06:56 PM
SLT8's Avatar
SLT8
105k i had the Sonnax and VB put in the same time around 4-5 months ago and is going great. Have 110k now. That said i avoid OD when doing WOT and try to avoid 2nd Prime downshifts.
Old Nov 18, 2010 | 10:19 PM
The Cank's Avatar
The Cank
The TMR mod changes the pressure in your transmission line to make a firmer shift.
Old Nov 18, 2010 | 10:20 PM
The Cank's Avatar
The Cank
I always turn off the Over Drive when I hammer it. But the downshifting... is it that strong ? also what is VB ? Im sure I know but I am drawing a blank.. And I can not find the wire on the Sonnax website...... Did you have a Sonnax transmission put in ?
Old Nov 18, 2010 | 10:39 PM
SLT8's Avatar
SLT8
Sorry i mean the Sonnax Line booster
http://www.circledspecialties.com/p-...e-booster.aspx
VB is short for Valve Body which i replaced with a aftermarket valve body.
Second prime is considered our weakest transmission shift.
Keeping it out of OD is trying to keep it out of 4th and 5th when going WOT as they are also weak transmission points.
Anyway you should be ok regarding your original question.
Shoot i just saw you have a 03. Are you referring to the TMR wire mod? If so then disregard my posts.
Old Nov 18, 2010 | 11:04 PM
kx250frider617's Avatar
kx250frider617
If its the TMR mod go ahead and do it, I did mine at 90k and it is soo much better. At WOT the shifts are firm and the truck lunges foward between shifts. Before it would slip and the truck would just die between shifts but not anymore.
Old Nov 19, 2010 | 08:53 AM
The Cank's Avatar
The Cank
Yeah the TMR Mod is what I was talking about. TCM wire mod ? Is that the same thing. I just did the power wire today and I wanted a firmer shift since the super chips tuner does not let you mess with shift points on the 03.
Old Nov 19, 2010 | 10:16 AM
SLT8's Avatar
SLT8
Its the same mod. Just a old mod that the name changes but the goal is the the same LOL.
Anway i am sure the Forgettern Members and chime in to see how thier tran's are holding up. It meant to be a easy mod with great results.
