If I just lifted my truck instead....
Old Nov 19, 2010 | 04:49 PM
i r grunt's Avatar
i r grunt
Default If I just lifted my truck instead....
of leveling it... would they be able to make it level during the lifting process or is that impossible?
Old Nov 19, 2010 | 05:06 PM
freestyledude's Avatar
freestyledude
99% of the time lifts also level the truck. The usual 4" lift lifts the back 2" and the front 4"
Old Nov 19, 2010 | 06:16 PM
Matt99's Avatar
Matt99
yea if you do a suspension lift it will be 2-3in more in the front generally
Old Nov 19, 2010 | 06:54 PM
CardinalsFan11's Avatar
CardinalsFan11
Yeah basically ever 6" lift you see is 6" in the front and 3" in the back. It is just much more expensive to lift than level, especially install costs if you don't know how to install it yourself.
CardinalsFan11
Also, if you lift it you typically want to get new tires, because the stock ones will look significantly disproportionate.
Old Nov 19, 2010 | 08:47 PM
HammerZ71's Avatar
HammerZ71
suspension lifts also level, body lifts lift the entire truck uniformly...
Old Nov 22, 2010 | 08:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Mine is lifted and leveled.
Old Nov 22, 2010 | 02:33 PM
Matt99's Avatar
Matt99
Mine is also lifted and levelled
